Spoolamatic 30a Wire speed
  • Spoolamatic 30a Wire speed
    Is it normal for the wire speed reading to fluctuate at the machine once it is set. Example wire speed is 400 set at gun reading on machine, Reading then reads 392,408,306,400,390,406,400....
    Is this normal, I do not detect any fluctuation in gun but that is hard to say...
    WIRESPEED
    IRAMBERSON I'VE SEEN SOME CHANGES BUT USUALLY VERY SMALL AMOUNTS LIKE 400,397,402,399 BUT NOT LIKE YOUR EXPERIENCING. HELP ROCK OR ANDY PISTOL8
      I agree "P8"
      What machine are you using?? Is it an XR box or a direct connect to a MM251?
      A-
        Spoolamatic 30 a wire speed
        Millermatic 251 direct connect to machine. Received message from Miller to have bypass capacitor replaced on the 10 pin connector by dealer. Andy have you seen Fluctuation in your usage with the spoolgun
          Andy and Pistol8,
          You guys are good! I can't push a bead and watch the meters. My 12RC has meters, but I don't have the feedback kit to make them function with my Trailblazer. As long as the beads are consistent I don't worry about wire speed.
            NOT THAT GOOD EITHER
            HEY HAWK I CAN'T PUSH A BEAD AND WATCH THE METERS EITHER AND I HAVE THE 210 BUT, THATS THE KEY WORD HERE MY BUDDY TONY HAS THE 251 AND I GET EXCITED ABOUT DIGITAL NUMBERS AND I WATCHED HIS AS HE WELDED.
            PISTOL8
