Jet 1024 Metal Lathe
  • Jet 1024 Metal Lathe
    Does anyone own a jet 1024 metal lathe
    I just bought one and have some questions
    On how to use the quick change gearbox
    Forsome reason I can't change it
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    (Retapped to fit regular mig tips)
    Work better & less parts to stock.
    Miller 130xp
    T/A Dragster 85 (portability 11 pounds)
    Oxygen/Acetylene torch set 50'
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    What are the actual questions. Pic would be helpful. Does it have the oil cups above the gear change lever?
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
      I guessing that you're having trouble changing from one gear setting to another. If that is it, install a chuck onto the headstock spindle and while trying to change gears use your other hand to spin the chuck. The gears aren't like on a synchromesh transmission and you need to help the 'change' a bit by spinning the spindle until they mesh correctly. I have the same problem on my Jet 14 X 40 lathe.
      Miller DialArc 250
      Lincoln PrecisionTig 275
      Hypertherm 900 plasma cutter
      Jet 14 X 40 lathe...ditto
      Logan 7" shaper
      Ellis 3000 band saw
      Lots of dust bunnies
        Thanks I got it figured out I guess the previous owner never changed gears I had to smack them with my brass hammer near the shaft. I oiled up they shaft the levers ride on and now they slide freely. Thanks
        Millermatic 211
        Spoolmate 100
        Miller 130xp
        2. 4-1/2" grinders
        1. 9" grinder
        14" Makita chop saw
          What's a good place online to buy a decent 4 jaw chuck. Mine came with a 3 jaw chuck.
          Millermatic 211
          Spoolmate 100
          Miller 130xp
          2. 4-1/2" grinders
          1. 9" grinder
          14" Makita chop saw
            Well....you might have opened a can of worms there. Depends upon what you consider a good chuck and the amount you are looking to invest in one. I don't know what style chuck mount your lathe uses (screw thread, A taper, D taper pin, L taper, etc.), but Bison (Polish manufacturer) makes a great chuck. Not cheap and probably more than you would want to spend on a small lathe. Look on eBay to see what is available as a 4-jaw chuck weathers the storm far better than what abuse will do to a 3-jaw...so a nice looking used one will work fine.
            Enco just had a one day 30% off sale that you missed. CDCO is cheap...can't say what the quality of their stuff would be like, but again with a 4-jaw you aren't going to have to worry much as long as the chuck holds what you need held.
            http://www.cdcotools.com/
            EDIT: Another couple of sources. I've only dealt with Plaza, but the owner is honest and if he has what you need the price is usually good for a used American made chuck...just download his list from the link
            http://littlemachineshop.com/product...gory=566826475
            http://plazamachinery.com/
            Hope that helps.
            Miller DialArc 250
            Logan 7" shaper
            Ellis 3000 band saw
              You can never have too many chucks. I have 8 for just one lathe. Different sized 3 and 4 jaws plus a collett chuck. I have a huge rusty 4 jaw that i love for bigger work and it fits the bill perfect. And i have a junk 3 jaw for crusty work that i don't want to chuck in a good chuck until the part is cleaned up. And i can make parts in batches of 8 just leave the part in the chuck and swap it for another one saving some set up time...Bob
                I 2nd Wyoroy on plaza Machinery.
                Guy has tons of highly serviceable merchandise.
                Worth a try.
