Im a beggiber welder going to school and working at a welding shop what is a better helmet the lincoln 3350 or the miller 9400I money nog an issue if other choices are better pleases let kno
best welding helmet
If there is any chance that you will be using it outside stay away from the 3350 like the plague. I got one for the advantage of the big window, which is great, but outdoors it's worse than worthless, can't turn the sensitive down low enough that it doesn't go dark every time you look up and if you try overhead on a clear day forget it.
Fussed with Lincoln for over a month about it and they even sent me a replacement lens which was no different than the original. Finally told me that engineering said that was the way it worked and that was that. I'm stuck with it.
I'm sure the Miller and Hobart hoods are good as I have a Hobart I've had about four years and it still works fine. Just wanted a larger window for the ease of my bifocals.Trailblazer 302
Lincoln SP-135-T
Hobart Stickmate AC/DC
Smith torch
Spoolmatic 30A
I use my Titanium 9400 mostly for GTAW and man it rocks. The headgear fits my noggin well with the occipital pad getting a good squeeze. The ratchet mechanism is solid, I take it on and off maybe 50 times per day, after one year it still clicks into place and stays there. Four sensors, WeldX mode for outdoors, alarm, arc timer, clock, all work very well. If you SMAW the external grind button is easy to toggle with gloved hands, the inside will flash red if you forget to return to Weld mode before the next arc.
The inside buttons are not raised so if you need tactile confirmation, try another brand.
Had an issue early on with the lens malfunctioning but Miller replaced it. The external lens covers are easy to replace, the inside will fit a standard magnifying lens.
Only two things I would fix would be more side coverage to cut reflected arc, better ear coverage and slope the shelf on the faceplate that catches sparks and melts the plastic. For that reason I use the 9400 almost exclusively for GTAW and a Fibre Metal passive for SMAW, especially cellulosic rods.
Never tried a Lincoln, no help there. You should look at 3M Speedglass too, hear good things about all of them except the headgear being a little cheesy and uncomfortable. The ones I looked at were solid though.
Good luck in school man.Dynasty 350
Bobcat 250
Maxstar 150S
Titanium 9400
Purox O/A
Cutmaster 42
It's really personal preference. There are a lot of really good helmets out there. My recommendation is for your primary helmet don't go cheap (not that you are).
aametalmaster has a really good point about the cover lenses. Having to get special cover plates won't bother you at first but after a while it most likely will. Personally, I wouldn't get a helmet that required me to get special cover plates (none of my helmets have them), or which were a pain to change, but that's just me.
I like my Jackson NexGen quite a bit. Also like my Jackson Halo X with a fixed shade #10 glass gold mirror lens in it. If you don't like really flexible helmets then the HaloX isn't for you. Have a couple other cheapo helmets with standard fixed shades in them as backups. Rarley use them though.
If you haven't already; go down to a few local welding supply stores (if you have them) and check a few out. Look at the head gear, cover plates, easy of operating the controls, number and type of sensors, etc and see what you like. Headgear that is comfortable, stays put, and which is operable with gloves on is a big deal for me. Also like to be able to adjust the controls with my gloves on too.
Have fun in school
Best welding helmet
It is about preference but a good helmet is a good helmet ; i have a tried many and let me tell you jackson true sigth is very good. I have some degree of color blindness and this one make my life easier the amber allows to see the puddle with better definition;specially when tig welding, read all the reviews out there and then decide whaht to buy
