What is the procedure to tig weld 7/8" diameter, .058" wall 4130 chromoly round tubing to 7/8" diameter, .035" wall titanium round tubing? What type of filler rod should I be using? Also what size and type of tungsten. Lastly, if anyone can expand on their experiences with welding titanium. Thank you
tig welding 4130 chromoly to titanium
It is definitly not done on a regular basis.. You are going where no man has gone before.... I borrowed thatAnyway, I fear that cracking will occur if this joint is subjected to any loads. We have had problems with Titanium shifter handles and the bolt that is welded to the handle breaking after welding.
If you do attemp this, Titanium is very atmosphere sensative. Weld this in an Argon chamber or at least provide a trailing gas to shield the weld area until the Titanium cools under 800 degrees.
Looking into what filler to use.
