150 tons of fun
  • 150 tons of fun
    So some of you may remember me asking around for 75 ton hydraulic cylinders for a press brake I planned on building. Found a couple cylinders about 3 months ago,so knowing what size and psi they were I had a pump ordered and built a 4 foot press brake. Pictures are from a month ago and it still sits now as it looks. I have not had time to do much else to it. It is functional but I still need to add adjustable stops, back gauge and a hold down for the bottom die.
    2- XMT's 350 cc/cv
    1- Blue star 185
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    2- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- DYNASTY 280 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74D
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Looks great. All the ones i ran just had a couple of rails for the bottom die to slide in...Bob
      150 tons of fun
      Very nice work !!
        top notch build for sure.looks like a future money maker.just wondering if you had any thoughts into making it wider so you could bend 8' and 10' sheets of plate. the shops around here that do all the plate bending make pretty good money .
          It will have a specific purpose. I have a 8 ft brake.
          2- XMT's 350 cc/cv
          1- Blue star 185
          1- BOBCAT 250
          1- TRAILBLAZER 302
          1- MILLER DVI
          2- PASSPORT PLUS
          1- DYNASTY 200 DX
          1- DYNASTY 280 DX
          1- MAXSTAR 150 STL
          1- HF-251 BOX
          1- S-74D
          1- S-75DXA
          2- 12-RC SUITCASES
          1- 8-VS SUITCASE
          2- 30 A SPOOLGUNS
            150 tons of fun
            Looks friggin' awesome!!
              Kinky!
                Looks manufactured, great job. Is that a foster pump?
                  It's a good thing, but I'd have to say, if this is for a small home shop, that it kinda falls into the OVERKILL catagory.
                  My sons are always saying that when I build something, it's always OVERKILL.
                  I tell them that I go by what my Dad used to tell me and that was, " In some cases, it's better to have and not need, than to need and not have."
                  That's a great looking press. Now I want to build a bigger one.
                  Bill
                  Miller Dialarc 250 AC/DC
                  Miller 251
                  Thermodynamics Plasma arc
                  Benard "Center Fire" wirefeed gun
                  Miller alum. spool gun
                  Tweco Tig torch
                  Victor O/A torches
                  B&D Wildcat 9" grinder
                  DeWalt 10 amp 4-1/2" grinders
                  7"x12" bandsaw
                  A shop that's always going to be to small.
                    A little mor info. Foster 3000 psi pump, frame 4"x8"x1" angle, a leftover 18"x65 pound per foot I beam for the bottom die. "still plan to add more plating around it." Paint will be last
                    Certainly not for hobby use. Mainly will be dedicated for 1/8 stair pans. Its max capacity 3/8 at 4 feet.
                    2- XMT's 350 cc/cv
                    1- Blue star 185
                    1- BOBCAT 250
                    1- TRAILBLAZER 302
                    1- MILLER DVI
                    2- PASSPORT PLUS
                    1- DYNASTY 200 DX
                    1- DYNASTY 280 DX
                    1- MAXSTAR 150 STL
                    1- HF-251 BOX
                    1- S-74D
                    1- S-75DXA
                    2- 12-RC SUITCASES
                    1- 8-VS SUITCASE
                    2- 30 A SPOOLGUNS
                      That looks great. It looks way better than Any manufactured brake I have seen that size. Also good job on the platform... looks great.
                        Have you thought of how to keep the rams even when bending? It looks like you have just teed the hose from the pump? If you bend off center won't the side with least resistance go down further? This would only be a problem when air bending & not die forming.
                        MM250
                        Trailblazer 250g
                        22a feeder
                        Lincoln ac/dc 225
                        MM200 black face
                        Lown 1/8x 36" power roller
                        Arco roto-phase model M
                        Vectrax 7x12 band saw
                        Miller spectrum 875
                        30a spoolgun w/wc-24
                        RCCS-14
                          Correct, but as mentioned earlier, adjustable stops will be added to each side for consistent and repeatable bends.
                          2- XMT's 350 cc/cv
                          1- Blue star 185
                          1- BOBCAT 250
                          1- TRAILBLAZER 302
                          1- MILLER DVI
                          2- PASSPORT PLUS
                          1- DYNASTY 200 DX
                          1- DYNASTY 280 DX
                          1- MAXSTAR 150 STL
                          1- HF-251 BOX
                          1- S-74D
                          1- S-75DXA
                          2- 12-RC SUITCASES
                          1- 8-VS SUITCASE
                          2- 30 A SPOOLGUNS
