I'm running a ranger 305g with 1700 hours on it. When welding it is popping and spitting more than normal. Tried different heat and compared head to head with other welders using the same kinds of rods and we can't seem to get it to stop. Does anyone have any ideas as to what causes big popping and spitting? When i say that I mean more than normal of course.
popping?
I think he means in the arc is having issues. Brendan can you specify as to which one it is?2- XMT's 350 cc/cv
1- Blue star 185
1- BOBCAT 250
1- TRAILBLAZER 302
1- MILLER DVI
2- PASSPORT PLUS
1- DYNASTY 200 DX
1- DYNASTY 280 DX
1- MAXSTAR 150 STL
1- HF-251 BOX
1- S-74D
1- S-75DXA
2- 12-RC SUITCASES
1- 8-VS SUITCASE
2- 30 A SPOOLGUNS
Could the metal be magnetized or could splatter guard have been sprayed on the steel?
Is the metal new or from a salvage yard where it could have gotten something dumped, spilled or sprayed on it and cleaned off ?
Sounds like the steel is the problem ifen everyone else is using the same wire and your machine works on other jobs......Last edited by tackit; 05-20-2013, 02:23 PM.
I would first start by checking to make sure the rpm is correct. Below is a link per Cruizers specifications.
http://www.millerwelds.com/resources...ighlight=meter2- XMT's 350 cc/cv
1- Blue star 185
1- BOBCAT 250
1- TRAILBLAZER 302
1- MILLER DVI
2- PASSPORT PLUS
1- DYNASTY 200 DX
1- DYNASTY 280 DX
1- MAXSTAR 150 STL
1- HF-251 BOX
1- S-74D
1- S-75DXA
2- 12-RC SUITCASES
1- 8-VS SUITCASE
2- 30 A SPOOLGUNS
My TB was welding crappy a wile back, turns out I had a poor cable connection. Swap cable from one of the good welders to check. I have had it weld poorly on other occasions because my son would play in the back of the truck and flipped the switches, or move the cables from CC to CV. Take a pic of the front panel as it is set up to weld and post it. Also, if there is a remote on there disconnect it and try.
