simple chopsaw stand
    Originally posted by clint738 View Post
    Interesting design. I like how it is portable with wheels. Does it vibrate around much when your cutting steel?
    No it stays put on concrete. It's whole purpose though is to be wheeled out in the dirt where all the grinding dust and dirt is sent to the ground.
    If I was to build one strictly for concrete I would put rubber machine feet on it for the real possibility of things getting under the plate and acting like bearings.
      we had one bench mounted and tried a few bandaids. I agree outside is a good idea and in many cases there is no ideal but I finally had it. Mine is used daily at any time, this isnt bad. There is a little band saw hidden behind it but its a last resort, chopsaw is so fast and versitile.
        For those interested who cannot view the photobucket crap.
          Cary that's got to be the best set up for a shop I've seen. Can you tell me what that screen is called and what size is it?
          Someday you should build a sand blaster cabinet out of an oil tank, you have the experience, ideas and probably the tank to do it. Around here oil tanks are more scarce then hens teeth. I built a pressure pot blaster to clean steel up and an old Wards garden tractor I wanted to restore but the blaster is to big for my compressor, it would take a hour to do both sides of a 14" rim.
