simple chopsaw stand
  • simple chopsaw stand
    I made this so I could roll the saw outside. I centered the motor over the 4" sq tube riser so down forces would go straight to the floor to help with balance when cutting. The angle irons end over the center of the axle. The handle slides in out of the way. For those that don't know, you can click on the double lines down at the bottom left by the pictures and stop the slide show and see the pictures one at a time by clicking on the arrows on the screen.
    http://s1298.photobucket.com/user/cy...deshow/Chopsaw
    I have never seen any of your pics. When i click on the link u paste it sends me to a sign in page. Am i the only one?
      Also... it may be cause im on here with a stupid.. i mean smart phone
        Pics work fine for me. Nice stand.
        CG
        Miller Diversion 165
        1945 Craftsman Atlas Lathe
        Smithy Lathe/Mill
          CG
          Thanks chewinggum, it's fast and easy to build and doesn't take a lot of material and shoots the dust and dirt to the ground. no clean up
            Weldon, I have it set to public, it should be showing up on your dumb phone.
              How's the new Bobcat doing?
                I am using my tablet now and its the same thing. A sign in/sign up for photo bucket page, no matter what I click I have to sign up for it
                  Its doing great. At 98hrs now so time for a oil change. It took a while to get used to it. Its a lot different than my other welders, completely different arc, its not better and its not worse... Just different. And also took a while to find that sweet spot, I change rods and sizes so frequently that I would forget where I was on the previous rod.
                    This is with the new bobcat and a hf-251d. No pedal, no on/off switch.. just a hot torch and a gas valve.
                      Another, same as above. As you can see in this pic... it is either too cold, or hotter than ****. It will do ok for non critical jobs but i wont do a whole lot of aluminum with this setup.
                        That's nice welding anyway, many welders say Bobcats are good machines, by the looks of your weld it's a true statement.
                          I have the same problems with your photos. Always asks me to sign in to view them. Not happening.
                          Miller 211 MVP
                          Hobart StickMate LX 235
                          Lincoln AC 225
                          CutMaster 42
                            The album says public can view it. The picture of a lock is unlocked. Must be your computers security settings are set to high for Photobucket.
                              Interesting design. I like how it is portable with wheels. Does it vibrate around much when your cutting steel?
