I have a rather cramped garage, so I want to put up some sort of wall or curtain around where I will be using the MIG. Not much of a clue as to what material I should use -- suggestions?
Weld shield walls/curtains?
If you go with a wall, a simple stud wall in either wood or metal studs with a sheetrock covering should be more than sufficient. Remember to tape and mud the joints. If you feel you need more, hardie panels, hardieboard, whatever trade name it goes by in your region.
If on the other hand you wish to go with curtains, try here...
http://www.google.com/search?safe=ac...L8nRiALL44HgCAMiller 251...sold the spoolgun to DiverBill.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
