metabo cust. service
  • tackit
    Originally posted by Sberry View Post
    I have one I have a big piece of tape on, rolled a pipe on it when it was nearly new. Its worked for a long time that way.
    I used a SS hose clamp and barb going to the female side of a disconnect for awhile, man I hated that set up, made me appreciate swivels and good hose.
  • tackit
    Originally posted by weldonwelding View Post
    Look what I just DID!!!!!!!! Man I can't keep a grinder! I was just beveling a pipe and the plastic inside that holds the cover on just broke.. u can sorta see it in the pic. I'm gonna try to tape it up or super glue it. Just thought it was funny that it happened to the one that tackit put a picture of.
    I would send or take it back, that ain't right. I never see anything like that before...
  • Sberry
  • tackit
    I like no whip on air, connect right at the tool. Especially in the shop where change out rate is hi. I can reach for an air hose at the bench but like electric on it, fed mine in the floor. I have used hanging but it still is in the way.
    The whip's swivels are nice and it's not a big inconvenience to disconnect... it's not a competition thing where each second counts. I hate even the slightest amount of restriction when I'm working with a tool.
  • weldonwelding
  • Sberry
  • Sberry
    I like no whip on air, connect right at the tool. Especially in the shop where changeout rate is hi.
  • weldonwelding
    Originally posted by mikeswelding:306907
    This is why I hate big businesses and greedy CEO's. Over 25 years ago I bought two Makita grinders. They have been used hard in my welding shop and have over-heated and shut themselves off more times than I can count. But that didn't mean they were done for. See the little button just above the cord on the attached photo? It's a re-set button. Let the grinder cool off, punch the re-set and you are back in business.
    Do you think these corporations have somehow forgotten that technology? Nope, it's called built-in obsolesence. Build a crappier product that fails and you can sell more of them.
    You have a good point. One of the company's I worked for had a very old all steel, heavy, 9" grinder that would rip you off a ladder with ease... Yep it threw me on a big pile of rocks at a stone and gravel plant. You couldn't kill that thing with 3 Paul bunyons behind it. I hated that grinder with a passion. My boss was about 75 yo, best welder I've ever seen, hardest worker I ever seen, he was old school to the bone, in fact welding killed him with cancer in the bones. He made me use that grinder every day, if I had it now it would be my go to large grinder
  • mikeswelding
    Big Business Greed
  • weldonwelding
    Buy good plugs and cut the wire that goes in the plug as short as possible. You will appreciate a replacement plug alot more. I paid close to 20 bucks a piece for the twistlocks. And the standard plugs i bought before were the best of the best about 15 bucks a piece, but well worth it
  • tackit
    I dunno if you can buy em or not. U buy the end, cut the cord and put the twistlock on. The application for this would be more useful in the field im thinking. Thats most of my work
    It's definitely and improvement. I hate cutting off molded plug ends. It would be nice if they made adapters that could be attached permanently to a regular plug.
    Maybe molded ears on the adapter for passing a nylon wire tie through and for the plug end a split ring with holes for passing the nylon wire ties through would work. Now to find a plastic mold set up on e bay.
  • weldonwelding
    Originally posted by tackit:306886
    I like the twist lock idea myself, I imagine you can buy extension cords with twist lock ends, right? Right now I have a 12 ga extension cord with a three way outlet that hangs down from the rafters about three feet off the welding table, It's kept wire damage problems down for me, really handy too.
  • tackit
  • Cgotto6
    I like the twist lock conversion idea. Like you said tying the cord in a knot to the extension always gets hooked on stuff. And Milwaukee's design with the quick disconnect on the hole shooters is sweet. Wish more tools had it. If it wears no brainer to replace
  • weldonwelding
    I like swivel whip hoses on my air tools to be 4' long so the connection doesn't get caught on anything under the hood. I would think 2' is right there in the way, just my opinion of course .
    My Milwaukee Hole Shooters disconnect right at the handle out of the way.[/QUOTE]
    I agree with that. But its a different story, air tools are used under hoods where an electric grinder isnt as much needed. Besides... the twistlocks are coated with rubber and their pretty slim. Im gonna try it, and will work out the kinks as i find em.. what gave me the idea was in a pinch one day my cord broke at 2' 1'' and i ended up cutting it at 2' .. it worked pretty good exept it kept coming unplugged until i tied it then the knot got in the way. I worked in a plant where everything was up to date inspected and it was all twistlock, everything. It was all uniformed, very neat, and mostly way overdone.
