90-95 is great man, thats a really good temp to start at. As you get better you can try different stuff. Until you get it how you want it though just do all of the steps the same. If YOU do everything the came everytime and it works then you can try to make it your own and tweek the technique.
stick welding open root
Everything you are doing is preparation for pipe. 1g is the top of the pipe, 3g is going vertical up the side and the bottom is the overhead, just remember the better you are at the plates the easier the pipe will be. You'll do great just stay calm and dont rush it. You have to like what it looks like, you are you biggest critic.. atleast you should be...
Originally posted by BearM View Post3/32 6010 at 90-95 amps? Way to hot yo.
Millers stick weld calculator shows 40-85A for 6010/6011 3/32" rods. I know you can probably run it hotter and travels faster, but isn't it advised to stay within the specified parameters?
I know that one problem I had when learning open root was that not really being able to see a puddle bothered me and, for some reason I wasn't PUSHING the rod into the weld far enough...so the instructors were on me to be constantly aware of the need to SHOVE THAT ROD IN THERE and keep shoving it in there!!!! The other thing that, for me anyway, was a great help with getting the rod in far enough to produce a good weld in the gap and get a good fill when you checked out the back side was that one of the instructors said to me that "The sound you get when you have the rod in far enough and are making a good root pass in the gap is like what you'd imagine it to sound like if a horse were peeing in a bucket." Now, I know that sounds like a sort of strange thing to think about when you are welding, but it sure did work for me and my welds improved like RIGHT NOW!!
Good luck and I hope that helps some.Don J
Reno, NV
Never pick a fight with an old guy. Old guys are too smart to fight and get hurt. They'll just kill you and get it over with.
