I am in my 3rd week of stick welding and having trouble getting consistent penetration on the bottom side. Instructor has us doing our root pass with 6010 3/32 electrode flat position. Any help or tips?
stick welding open root
Ok. So open root 1G. This is how I do it. So I will start with the prep for the weld. First thing I do when I'm testing is clean the whole plate both sides and the bevel and make sure before you put your land on that it is straight.... it super sucks to have an uneven gap.... you need you fit up to be the best it can possibly be for a test.
I keyhole mine I will start out Left and move to the right. When I start out its usually around 95amps. When I starton my tack I make sure as I move ove the edge of the tack that I blow through the part I knife edged. That makes sure that its tied in. After that I use whipping motion to from the left to the right, I just make sure that I watch my weld to insure that the keyhole stays open as you go to the right you look for that keyhole to open up. When it does you move back to the left to put some more of your weld in and just do it at a consistant pace.
