Cutting Cast Iron with Plasma
    garcia
  • garcia
    I would
    use a "Saw-sall" if you have room to use one in there. I have a plasma too, but like you mentioned, will it change the metal characteristics(crystallize the metal around the cut)? Someone in metallurgics should be able to jump in and help you.
    G.
  • KS2K
  • KS2K
    started a topic Cutting Cast Iron with Plasma
    I am repowering a 1943 Dodge Power Wagon with a Cummins Diesel. The old rear motor mounts are also the spring perch. I need to cut the motor mount away from the spring perch. The cast is .3750" thick.
    Can I cut this with Plasma or will I get Hydrogen Embrittlement and weaken the spring perch ? I will be cutting right up to the spring perch. If plasma is wrong, what is suggested.,
    Paul
