I am repowering a 1943 Dodge Power Wagon with a Cummins Diesel. The old rear motor mounts are also the spring perch. I need to cut the motor mount away from the spring perch. The cast is .3750" thick.
Can I cut this with Plasma or will I get Hydrogen Embrittlement and weaken the spring perch ? I will be cutting right up to the spring perch. If plasma is wrong, what is suggested.,
Thanks
Paul
Thanks
Paul
