Any one own Precision Instrument torque werenches
  • Any one own Precision Instrument torque werenches
    I need to buy new 1/2" and 3/8" torque wrenches. Anyone own a Precisian Instruments tool. There are so many cheapies out there it's hard to tell what's a good price for a quality tool. Precision Instruments is made in the USA. I would hope it's a better tool than a relabeled Chinese $30 dollar tool that sells near the price of a Precision Instruments.
    I have some nice Craftsman torque wrenches and also I have a unit that fits between the ratchet and socket with remote digital readout on torque. With adapters it can be used on different size drives and reads in different measurements like NM, inch pounds, foot pounds
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
      monte, the 1/2" Craftsman only goes to 150 ft lbs, I want 250. I'm replacing Craftsman, I left mine out in the shop all these years and I'm thinking the extreme temp changes is what caused the grease in them to cake up, they were stored in their plastic boxes, they froze up, their handles wouldn't turn.... The new ones are going to be kept in the house.
        What about the old "beam" style torque wrenches? Not much can go wrong with them, and if the pointer gets out of alignment, you just bend it back...
          My old eyes like the click type of torque wrenches better. Especially in places where there is little light
            I've read that the beam torque wrenches are more accurate and repeatable than the clickers. Purportedly the top teams all use beam wrenches. I used to have the name of the recommended wrench written down but ****ed if I can find it now.
            Maybe do a search on the SpeedTalk.com forums....
            Miller Diversion 165
            1966 Bridgeport Mill
            Leblond 15x 35 Regal Servoshift lathe
            Solberga SE 1425 Drill Press
            Bigass Bandsaw
            Hydraulic press
            small surface grinder
            Belt sander
            Tons of grinders and hand tools
            Knife edge Balancing rollers
            Heat and AC in the garage
            Jags and racing Triumphs
              Look on eBay at CDI. http://www.ebay.com/itm/CDI-TORQUE-W...item1e568a62cf
              and http://www.ebay.com/itm/CDI-TORQUE-W...item20c30c867c
                In theory they are but in tight places and where there is no light it's not easy to read a beam. I like a clicker because I set it and forget it, that's why I want good ones.
                  I wish I had seen your post earlier cope, I would have saved a few bucks. I'm going to try and cancel my order.
                    Snap On digitals are great I have the full set.
                    Ji
                    Grip it and Rip it
                      tackit, the micrometer type torque wrenches need to be set back to zero after each use to keep their accuracy. I think you meant set it and forget it while in use, just wanted to be sure.
                        I didn't know that Cope. Thank you for the tip, it's much appreciated.
                          Ji
                          Jigantor I think CDI is Snap On. I doubt I could afford their digital torque wrenches. G'day mate to all you Aussies, nice to have you on the board.
                            Take a close look at the CDI wrenches in the link. Note that the 3/8" only goes to 21.8 ft/ lbs (250 in/lbs).
                            I recently needed to replace some 20+ year old torque wrenches and, after a lot of looking, I found the digital torque wrenches on the Eastwood.com site. The accuracy specs are excellent compared to others plus they have the 72 tooth ratchet vs about half that for most others. I bought one for my son for Christmas. I will be using it in a couple of weeks to replace the head gasket on his car. Then I will know how good it is. At this point, I can only say that I have been very satisfied with everything that I have purchased from Eastwood and I have high hopes for the torque wrench.
                              Dave I want a in/lb torque wrench for small bolts going into aluminum. The Eastwoods are nice wrenches, if they made a in/lb torque wrench I would consider them.
