Anyone gotten cracks in their shops concrete floor from using red heads
    Cgotto6, I agree with you, wedge anchors will work.
    Tackit, Basically all wedge anchors are about the same so whoever you talk to didd'nt have a clue about that they were talking about.
    A Hilti wedge anchor in 4000psi concrete with a drilled hole at least 2.75" deep using a 5/8" x 3.75 wedge anchor has a pull out strength of 1860 lbs.
    Go to Hilti and punch in item # 00282572 that will be a number for ordering a box of anchors.
    So if you put one anchor in the 4 outside legs you will be good up to 7,440 lbs.
    Keep in mind that was a minimum drilled hole specification, the further you drill the more it will increase your pull out power.
    Trust me when I say your over thinking this job.
    I use Hilti epoxy all the time which is no doubt better than a wedge anchor in a pull out application but I usually only use it when I have to bolt machined down that vibrate or when a engineer specs it.
      I have also used them and others over the years with no problems to speak of,I do use the Hex headed thread style now that 3/8" dia. and larger I use an electric impact on after I predrill the hole.I like them for the reason if you need to remove your item thier is no stud sticking out to trip on and they just look cleaner.Getting ready to set a 15' cross on the side of a church with them in about two hours.I agree that the two part expoxy woul be pricey for this But cracked concrete is sucky.Good Luck
        Thanks for the input from all of you, it's much appreciated. I don't care about the cost of the epoxy, it's still a whole lot cheaper than a trip to the Emergency Room. I'll do some thinking on it. Naturally I want to go with the safest but also the easiest solution. thanks again guys.
        So far it sounds like epoxy holds the best, am I right?
          Originally posted by Wen Valley View Post
          I wouldn't mind a redhead in my shop, not sure what the wife would think though...
          It would probably depend on how fat HE is.
            The spokesperson at red head is just covering their *ss. They will be plenty sufficient in this application. The epoxy would be like using a semi truck to haul a couple 2x4's. wedge anchors as i have already said are incredibly strong, even pull out. You could even use 1/4" ones probably and never have a problem. 4 @ 5/8 is so overkill it's a joke. And your going into seasoned Crete, which is better for this type of anchor.
            I have had to bed wedge anchors only 2 1/2" due to hydronic heating lines being cast into a slab, and when bolting down the mud sills with my 18" wrench I can practically sink a 1 1/2" diameter washer through a 2x6 if I wanted to do so. They just keep on crushing the more I torque them. I have never pulled an anchor out no matter the size or torque applied.
            • #21
              Cgotto6, Your semi truck to haul 2x4s is a perfect analogy.
              Installing concrete achors dont cause your concrete to crack, If you were worried about cracks you should have put rebar in it.
              Forger, What was the wall made out of that you mounted the cross too.
              • #22
                Looks like you guys are right. Red Head's chart gives pull out strength on a 3/8 X 2 5/8 Trubolt wedge anchor as 3,469 lbs.
                • #23
                  Exactly. Good luck with your table. I like to position what ever I am securing in place, with slightly over sized holes than the anchor, then roto hammer right through the flange, pound in the anchor with washers pre installed till it bottoms, then tighten her up. That way there is no chance for misalignment.
                  • #24
                    Thanks for the tip Cgotto6. I left a message with the son to see if he has a roto hammer I can borrow. I have to find the anchors tomorrow. I might have to order them. I think I'm going with 1/2 X 3.
                    Should I drill a 9/16 hole? I was going to drill a 1/4" pilot hole first then drill the larger hole is that OK? I don't have anytime running a Roto Hammer and don't want to make a mess of it.
                    • #25
                      4 Inch thick seems quite thin for shop floor....my house here in TX built in 2006 has 8 inch thick for the house and my garage (1,800 sq ft) I specified 10 inch and it is poured with a waffle pattern on 3 ft squares at 16 inch thick and it all has rebar. I did this because I had planned to install a lift (8,000 lb capacity) for lifting my cars and pickup (5,600 lb) I have been in here now since Sept 2006 and not one crack.
                      Roger Troue
                      Retired since 2004
                      Miller 211
                      Miller 200 Syncro
                      Miller 375 Extreme
                      • #26
                        1/2 anchor. 1/2 hole and no pilot needed. Blow the dust out.
                        • #27
                          I don't park vehicles or work on vehicles in my shop, it's just a hobby shop, I don't have any cracks in 10 years now. 8" of concrete would be insane for what I do.
                          • #28
                            Sberry's got it, bit size matches anchor size. It will say on the packaging. These are stocked in all sizes at Home Depot and lowes btw. Don't know if you have either of those near you.
                            • #29
                              Tackit, When Cgottosaid said oversized hole in a earlier post I'm pretty sure what he meant was to make sure the hole in the steel plate was at least a 1/6" bigger than the hole that you drill into the concrete, Otherwise the anchor itself will get caught on the steel plate.
                              The anchors are a tad bigger than the hole you drill in the concrete.
                              Like S Berry said, Do not pilot drill and use a 1/2" bit for a 1/2" anchor.
                              Cgotto6, I have never heard of a ROTO Hammer, Here in the big city we call them a Hammer Drill.
                              • #30
                                TxDarth is that a frustrated mechanic hanging from your ceiling in the 1st pic?-Meltedmetal
                                ---Meltedmetal
