welding outside recommended parameters
  • welding outside recommended parameters
    What type of weld quality issues will I see if I weld outside the ranges in the manual or the on the door of my Millermatic. Specifically, 'I'm looking for what problems I can expect when trying to weld 24 ga. sheet with 0.024 solid wire and CO2 shielding?
    Try some different welds on different sized steels thats how you learn. 024/co2on sheet metal might work well for some people and not others....Bob
      If you're worried about the wind, just put up a blind. It should work well for you !
      .........Norm
        I weld in my driveway all the time with .030/c25. As long as there isn't a big gust of wind there is no issue. You can just run a little more gas flow if you are having trouble in mild wind.
          He isn't welding outside😊
          He is welding outside the recommended parameters on the chart supplied with the machine😜
          Ed Conley
          MM252
          MM211
          Passport Plus w/Spool Gun
          TA185
          Miller 125c Plasma 120v
          O/A set
          SO 2020 Bender
          You can call me Bacchus
            two things can happen, one , it will run like crap, and two, it will be from ok to good, those door charts are starting points. some thing that i never hear on this forum is the need to change settings due to temperature, time of day, ect, in some locations, the juice from the pole will vary, on hot days, it can be low, air conditioners are running ever where, so the wire speed may need to be lowered, or on nights and weekends when there is little industrial use, the line voltage may be higher, causing you to raise your wire speed
              For me those settings are always on the hot side. But I have only used about 6lbs of wire with it or any Mig.
              So I set for the wire size (211) and usually decrease on the thickness scale. That may be wrong but its worked ok thus far.
              In most cases I run it hot even still just turning back if I can't keep up with the puddle or burn thru is looking likely.
              My first Mig experience was nice, had that nice sound going on thin stuff. Starting at about 3/8 I can't seem to find that sound as much. Everything is short runs I'm not getting any better like that.
              I would like to do more like Bob said. Try a bunch of different things and learn more.
              Its hard to waste for practice but its necessary. Done a personal project last night. It should have been perfect for Mig but I had only one shot so I got out the Tig. Another no learner.
                He isn't welding outside
                He is welding outside the recommended parameters on the chart supplied with the machine
                Oops, you are right. Should have read it more carefully.
