Hobart Handler 140 .023 roller part #?
  • Hobart Handler 140 .023 roller part #?
    Hey guys. I just bought my bro a gas bottle and .023 wire for his new Hobart Handler from Tractor Supply. I know these machines are essentially a millermatic 140 machine but made a bit cheaper. Does anyone know the part number for the drive roller for .023 solid wire? Thanks. Dave
    Should come with a combination .023-.030/0.35 roller. You just flip it around to go from .023 to larger wire. If it has a feed roller, it's probably the right one. You can download the manual here.
    http://www.hobartwelders.com/om/0900/o925f_hob.pdf older model w/4 taps
    uses 202 295
    http://www.hobartwelders.com/om/6digit/o258267a_hob.pdf new model with 5 taps
    uses 037 338
      http://www.millerwelds.com/om/t225716g_pt_mil.pdf
      18 . . . . . . . . . . . . . . . 220 179 . . ROLL, feed .024, .030/.035 .
      Doesn't your roll have 2 grooves? One side for the .023 and the other for .030-.035?...Bob
        Bob, is that a Miller PN? The ones I found at Hobart are different numbers.
          Yes it is...Bob
            The new 140s come with an .030/035 drive roll
            .o30 for solid wire
            .035 for fluxcore
            Drive roll chart
            http://www.hobartwelders.com/product...0-187-210.html
            Ed Conley
            MM252
            MM211
            Passport Plus w/Spool Gun
            TA185
            Miller 125c Plasma 120v
            O/A set
            SO 2020 Bender
            You can call me Bacchus
              This....the .035 side is a toothed groove while the .030 side is smooth...I think I ordered the right one from cyberweld today.....we shall see.....seems the miller rolls are narrower than the hobart?
              .o30 for solid wire
              .035 for fluxcore
              Drive roll chart
                Hopefully you ordered a Hobart roller. The Miller may well be a different part.
