I need help, I am trying to remove a bearing froma shaft ,very little access to it and I would like to save it and the shaft , I need to add that I tried a 3 jaw puller to no avail and there are 16 of these at 2500.00 a pop please help . would dry ice help?
frozen bearing
Originally posted by SNUNEZ View PostI need help, I am trying to remove a bearing froma shaft ,very little access to it and I would like to save it and the shaft , I need to add that I tried a 3 jaw puller to no avail and there are 16 of these at 2500.00 a pop please help . would dry ice help?Richard
A picture would be a real help. What type of bearing are you dealing wtih?
Some bearings will bind on the shaft when you pull on the outer race.
Dry ice can sometimes be a help. Liquid propane used to work, but not so much any more. It doesn't seem the same.Jeff
Is it possible you could use a slice wheel and cut short of all the way through the bearing's race.
Also could try putting some pentrating oil on the bearing and with a piece of brass against the end of the shaft hit it with an air hammer. I'm thinking the shaft is out of what ever it was in and on the work bench.Last edited by tackit; 04-01-2013, 05:28 AM.
Originally posted by cruizer View PostI use a plasma cutter, pretty easy, just have to have a fire extinguisher handy, one the bearing shell is off, the bearings or rollers come off, then all I do is heat the bearing collar with the plasma, and out it comes
Cut off the outer race with whatever, then cut the inner race almost through in a few spots and it will pop off. I have also used a cutting torch, and a plasma to scarf off the race. Once the inner race get good and hot in one spot it will generally come off easily. Want to work fast so as to not put too much heat into the spindle/shaft.
Originally posted by Daniel View PostI do you heat the collar with a plasma? I might use this process if it is easier then a oxy/ace torch or rosebud or tiger torch.
Originally posted by cruizer View PostEasier and safer than anything else I've tryed and it doesn't scar the $$ shaft. Gotta be on the lookout for grease fires though
Originally posted by Daniel View PostBut how do you heat the collar with the plasma? I'd like to know, if it's easier to heat with it I might try it next time I have to do it. I didn't know you could heat steel with a plasma torch.
