Welding alum
  • Welding alum
    I'm new to welding and have a miller 135.
    My question is do I need a shielding gas to weld alum
    or can a flux core wire be used?
    Al with Miller 135
    It can be done with 100% argon for shielding gas. Check with your local dealer. You will probably need the Al accessory kit with a different liner for your gun. Try to keep the gun hose as straight as possible and start with a stiffer wire like 5356 to give better feeding. The low amperage/duty cycle will limit your material thickness as well-probably 1/16" or maybe a little thicker. Be sure to clean your surface before welding. A good brushing followed by isopropyl alcohol should work. This is more of a hobby type machine. At any rate it will be a lot of fun and a great learning experience. One more tip: be sure and push the gun while welding Al-do not pull it. have a lot of fun and let me know how it turns out.
      Al with Miller 135
      kward11.
      On the thickness you can probably do 1/8" at the max.
      It's always good to see another welder join the crowd.
      again, good luck!
        KWARD111..............Ah your about to have some fun........ Aluminum is quite hard to learn to mig weld........... Also worth noteing is the fact that you will need to travel 1/4 to 1/3 faster than you normally mig weld at........ Do not stay in one area too long as the aluminum will shrink and crack or burn thru.....The best advice I can give you on this is practice, practice, practice......... The skill level is obtainable thru practice..........Good luck..........Rock
        [email protected]
        ROCK
