I'm nearing a plasma cutter purchace. I want excellent 1/4" finish everytime I use the machine and it has to be able to cut decently through 3/8" and torch cut quality through 1/2".
I will be using the cutter to trace templates I have made for brackets that I need to make multiples of. And I dont want to have to grind on these when I'm done, they need to have a good finish right from the cutter.
Having said all that, is the Spectrum 375 borderline? If it is at all I'd rather spend the few extra hundred on the 625.
thanks a lot!
thanks a lot!
