I just sit the fire extinguisher there, don't know if I would be carrying that one. It holds a good bit of water but a little red dry chemical maybe better and have the larger close by.
I like the idea of a cage but why can't you pull two swivel wheels in the front with a handle long enough so you don't run over your heels? if I cage it, I can push or pull. I guess your stating the standards, thanks.
Its 31" wide 48" long. Should fit through most doors, mine anyway.
Thanks again for the ideas
If you have a long handle like a wagon then yes but the wheel geometry works a little differently , but for carts with swivel castors usually much easier to steer the cart by pushing.
Ed Conley http://www.screamingbroccoli.net/
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
I've always wanted to buy an old Ford Ranger or Chevy S10 and make it into a flatbed, put a gas drive on it, something small for on the property and to help my farm neighbors out.
