I remember Andy once mentioning that certain MM251 settings verged on globular instead of short circuit transfer (I assume globular is bad?).
What would be the machines limitations for short circuit using .035 solid wire and 75/25 gas mix?
What are the recommended parameters/settings for welding 3/8" to 1/2" plate steel for single pass? Is short circuit possible, or is there a different recommended setup?
I read below that "Dan" claimed he would never try and weld a trailer hitch using short circuit which got me to thinking why he would say that? I know spray is a deeper penetrating/more fluid method, but it's my understanding it isn't for all position welding (overhead, etc). I've also never welded Mig in any other setting other than short circuit.
So, please give me the rundown on recommended setup for welding 1/4" and thicker materials, single pass using the MM251.
I've already welded 1/4" single pass with .035" solid wire (75/25 gas mix) with good results, but just in case I need to work on some thicker stuff...
thanks
Todd
thanks
Todd
