TIG guys......feeding the filler technique?
  • TIG guys......feeding the filler technique?
    What do you guys use for feeding the filler through your fingers without having to pause and restart the arc? I am confident in my welds as long as I don't span more than 6-8" of filler because I am not steady enough to hold it much further out and I am not using proper technique to feed the wire through my gloves. I feel this is what separates a good tig welder from a really good tig welder. Dave
    I hold the filler rod like a pencil, and use my thumb to feed the rod through my hand.
    There are a couple of videos that Jody did at weldingtipsandtricks.com on aluminum TIG welding where he demonstrates a couple of techniques. Highly recommended.
    _kevin
    Syncrowave 250 Analogue
    Maxstar 200SD
    Maxtron 450
    IntelliTIG 40
    S64M Wirefeeder
    Non-Blue:
    Hypertherm PowerMax 1000G3
    Lincoln Precision Tig 275
    Lincoln WeldPak 155
      I hold the filler rod like a pencil, and use my thumb to move the filler rod along.
      There are a couple of Aluminum TIG welding videos at weldingtipsandtricks.com where Jody talks about the various methods of feeding filler rod. Highly recommended.
      _kevin
      Maxstar 200SD
      Maxtron 450
      IntelliTIG 40
      S64M Wirefeeder
      Non-Blue:
      Lincoln WeldPak 155
        My excuse is I don't tig everyday so I don't get enough practice at feeding it. I just back off on the peddle to still keep a small arc so I don't lose my place. Then I push the back end of the rod against my body etc. to feed it through another 6-10" & pick up where I left off.
        On the stuff I do I have found it doesn't matter if I can feed it smoothly or not.
        MM250
        Trailblazer 250g
        22a feeder
        Lincoln ac/dc 225
        MM200 black face
        Lown 1/8x 36" power roller
        Arco roto-phase model M
        Vectrax 7x12 band saw
        Miller spectrum 875
        30a spoolgun w/wc-24
        RCCS-14
          I hold the filler rod like a pencil, and use my thumb to move the rod through my hand.
          Look at some of the Aluminum TIG welding videos at weldingtipsandricks.com for some examples of techniques.
          Highly recommended
          _kevin
          Maxstar 200SD
          Maxtron 450
          IntelliTIG 40
          S64M Wirefeeder
          Non-Blue:
          Lincoln WeldPak 155
            Somebody here recommended sitting around with a glove on and practice. I have done that but you need an aiming point. I could feed pretty good then trying it for real the end of the filler wire was all over the place.
            It does help tho.
              The glove practice works a lot you just have to find the way that works best for you. I use the pencil method too expect I don't push with my thumb I hold with my thumb and use my index and middle finger to feed.
                I have been tig welding for years and I'm with MMW. I usually let up on the pedal a bit and push mt wire against my shoulder or the front of my hood.
                  I do the same as bellboymotorsports. When I started I would practice feeding, with a tig glove on, while sitting in traffic on my way to work. I would feed 4" and push it back with the dash. I would only use about 10" of fill though. You could try this also. http://m.cyberweld.com/tigpen.html
                  It's a filler rod feeder. I tried it while learning how to feed. I like the thumb and 2 finger method better.
                  Kevin
                    I feed with my index and middle fingers, I use my thumb to put a constant slight pressure on the filler rod to keep it stable. I can tack weld 10' of filler together and weld a joint with it non stop. Saves a huge amount of time versus bumping the filler out with your shoulder ect.
                    Miller syncrowave 200 runner with coolmate 4
                    and wp2025 weldcraft torch
                    Miller 125c plasma cutter
                      The Tig Pen really helps too.
                        Try feeding the wire between your ring finger and your middle finger and slowly push with your thumb leave your index finger free. Also you can practice by taking pair of thin cloth gloves (brown jesery gloves you can buy at dollar general or a store) and start with a piece of 1/16 wire a full stick and start buy placing wire in between ring finger and middle finger and slightly make a C shape with your hand and slowly push rod with your thumb. Trust me it takes practice but if you have free time just practice and it time you will get the feel
                          I have a 4' X 16' fab table and I don't know what I would do with 10' of filler. I hope your Joking!!!! I just can't see wasting the time to tack 10' of filler together. Just my .02
                            Lol no I don't actually tack filler rods together. Just making a point. I have seen others weld and stop to bump out more filler rod, if you added up all the lost arc time it would be surprising, not to mention all the stops and starts in your welds.
                              Cool, I thought so. With a little practice it's not all that hard to get the hang of advancing the filler.
