stainless steel mig welding
  • stainless steel mig welding
    I have never welded stainless before but I might be faced with it soon. Any tips? Pointers? Things to expect ? Thank you
    Make sure you use a trimix gas.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      What kind of wire is best? I know between .030-.045 in size
        Not to overstate the obvious, but you will need stainless wire, probably 308 - it depends on the parent metal alloy. Size, of course, will depend on thickness of material and amps.
        Stainless warps like crazy when heated, so clamp, clamp, and then clamp some more.
        What he said about tri-mix gas.
          Two more thoughts - stainless wire is not required for welding stainless, but if you use regular E70[xx], then the weld itself will rust. Also, depending on the structure of what you are welding, back purging may be necessary to prevent contamination. A thread search will tell you all you need to know about that.
            Thanks
              are you welding SS? we weld on dipper buckets parts made of manganese with 309 and use C25 and it is the same way as any other fluxcore, use the voltage specified and adjust your wire speed.
                I haven't welded stainless yet, the opportunity might be coming though
                  ss wire
                  i would suggust getting the L Si in the wire, So if 308 L Si, 309 L Si, or 316 L Si, it will run much smother.
                  Miller Syncrowave 200
                  Miller Spectrum 875 Plasma Cutter
                  Miller Milermatic 135
                  Ridgid Drill Press
                  Ridgid Chop Saw
                  36" Metal Break
                  Harris Toarches
                  English Wheel
                  Ingersoll Rand, 18.1 cfm Compressor
                  30 gal. Sand Blaster
                  Planishing Hammer
                  150lb Anvil
                  10" Swing Logan Lathe
                    I just did some SStl MIG at work, and I must add that out of position welds suck, just like using 308 stick.
                    AutoArc 230 (MM 210)
                    3035 spoolgun
                    Spectrum 625
                    Dialarc HF w/Coolmate 4
