Spectrum 187 Plasma Cutter
  • Ok gonna try running 50mt060whtapbf as a 50mt060ulsappbf just not using station 11 and twelve whats the worst that could happen?? Oh yeah q9 on board for what feeds oc1that feeds vr 4/hs2 not on diagramming leap of faith?
    • Might have found sorta a problem
      • Pm1
        • Ok we got power up.but overheated light on?? Fan runsno other lights ummm gonna take it apart again ee how transformers look hopefully get some help frankenmiller has signs of Lifehouse with the abuse to that board it has life
          • I can't remember which one is pm1, is that the input rectifier or output IGBT? What are you showing for input bus voltage on power up? Should be ~390VDC.
            • Yes was getting just about a little over 300v not close to 390 hey there's life out there. As the 50mt060ul boost buck modual seems not easy or cheap to come by I had a thought ha ha microchip mscsm120am31ctbling as a replacment for at least the 50mt060whtapbf yeah in know its not a plug an play situation the pins are in diffrent places but frankenmiller couple jumper cables lol hey nice to hear from yall
              • Another though. Ummmm. How about wiring 2 sot227 s together in some form lollies the ga10up60 s or i have 10 apt60ge80jd60 and couple ufb200fa20p ju s
                t thinking getting cold again snow tommorow yeah
                • Whatever you do on the input rectifier, just be sure it's getting enough cooling. You could replace the low side chopper (boost module) with an IGBT and a high speed diode, though the snubbers on that board are tuned to the original components. Again, cooling may be an issue. I think the frankenmiller would need a much bigger box to fit discrete components with a reasonable life expectancy.
                  • Vs gt 100a65uf vishey.tech.said this would do a better job and all the point you have stated how you doing i might have an mpt modual lined up.the correct one there really not avaliable in usa for some reason?? Would really go the way it came i m.working on second board did really massacre the original.you.can.see where thing go without the copper slab out.of the water the 45xp.oh its the new g friend light two no problems going. Good thanks for advice. Oh the 3 transformers managed to.obtain a schematic but only partial the main power some of the other systems i m still.guessing still.tryingtho thank you
                    • As to.where the 28v and 5v come from the invisible connection I take that 1st small.1 is 28.the main is?the last one is 15 pm2 is drop.to 5v pm3 is 28v total.guess herethen.goes thru freqency mod to the next one and so on to the pcm then it starts this not righrsorrta getting it missed sr1ummm
                      • Umm unapproved
                        • Its getting fun quite expensive time consuming winter ab more rona coming and christmas
                          • The cramer little transformer c6obj2 any idea what it does its it for pilot arc start??
                            • If you're talking about the transformer in the middle of the board, it provides most all of the power to every controller on that machine.
                              • Thought that I wrote my though on how it works but it was unapproved prob wrong anyway not messing with.it then going back look when something happens be back oh that little max 43 really decent machine
