welder problems
  • welder problems
    I have a maxstar 200 sd and a dynasty 200 dx and I have installed a 220 outlet in my garage. it is the style of outlet that a lot of dryers use - 4 pin. when i plug in either welder and turn them on they make a weird noise buzzing type, and the number -2 flashes on the display. I have already toasted one power inverter. I am not sure what is going on
    while a very light sounding hum is normal a help 2 is not. Did you use the red wire by chance?
    2- XMT's 350 cc/cv
    1- Blue star 185
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    2- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- DYNASTY 280 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74D
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
      welder problems
      not sure what you mean the red wire. in the plug i connected the red, black, green, and white wires to their terminals. the noise is very loud and not normal and continues after it is turned off unplugged and then slowly dies down until it stops.
        what happend to the owners manual?
        You are not supposed to use the red wire. That is for 3 phase!
          Very important question, do you actually measure 230V/240V across the two designated hot leads of the receptacle you put in?
            As mentioned the red wire on the welders is for 3-phase power
            Since you are using it on Single phase you only use the black,white and green wires.
            The 4-wire receptacle you have is a single phase 120v/240v circuit: 120v for lights, timers on the dryer and 240v for the heating elements.
            On the Dryer plug in this application for the welding machine you Only use the 2 straight blade and rounded( ground) terminals NOT the L shaped terminal.
            The white and black can go either straight blade
            Ed Conley
            MM252
            MM211
            Passport Plus w/Spool Gun
            TA185
            Miller 125c Plasma 120v
            O/A set
            SO 2020 Bender
            You can call me Bacchus
              welder problems
              i have hooked up the plug as directed with three of the four terminals without the red wire. I is doing the same thing. Will hooking up all the wires on a single phase source damage the welder ? Any one know what the -2 means ? When I turn it on the first thing it displays 243 891 then -2 and right display is blank. then it goes to the normal operating display.
                Time for an electrician, cause what you've done is entirely stupid, no wonder why you've roasted machines.
                UNPLUG EVERYTHING and phone up someone who has a clue!!
                  Sounds like you might have hooked up the power in your shop incorrectly, but I have no idea.... The red wire is only used for three phase , that's all I know.
                    welder problems
                    the power in my garage is fine. at the time i did not realize the plug configuration was different for single and 3 phase. now i see my mistake.
                      Normal on the readout, not sure on the noise but as mentioned it will make some noise
                      Read your manual !
                      3 Arc Timer Display
                      Upon power up as described above, the meter S LED will turn on, and arc time will be displayed for 5 seconds as [000 000] to [999 999]. The first four numbers indicate hours, and the last two numbers indicate minutes. Arc time shown in example is read as 1,234 hours and 56 minutes. Maxi- mum arc time is 9,999 hours and 59 minutes.
                      Ed Conley
                      MM252
                      MM211
                      TA185
                      O/A set
                      SO 2020 Bender
                        That is why Miller includes a manual with their machines. Also available on-line.
                        Griff
                          Help 2 indicates an open in the thermal protection circuitry located on the bottom heat sink. Contact a factory authorized service agent if this display is shown.
                            Hlp 2 actually means a variety of things, and so far never found it to be a thermal.
