.052 overkill?
  • .052 overkill?
    I'm using .052 solid core wire to weld 3/8 to 1/4 domex, always seem to get a little undercut no matter what I try, opinions on this please
    U can make that work....lower the voltage a bit and or raise the wire speed....let it freeze a little quicker...
      under cut
      How does your welding supervisor say to fix it. Just curious
      ARMOR
      MOBILE WELDING&SERVICES
      Trailblazer 302
      X-TREME 12VS
      Spoolmatic 30A
      Millermatic 135
      WeldCraft WPseries TIG torch
      Smith oxy set.
        Thank you turbo, I have been running at 30 volts and just a hair above 4 ipm, Friday before I left work I turned my machine down to 28. I will raise the wire speed monday and let you know how it turned out. And actually right now we don't have a supervisor, and when we did he wasn't very knowledgeable on welding
          .052
          I bet if you look at your wire again you will see it's metal core not solid. Your numbers don't sound that bad to me. I would try changing your gun angle a bit and your travel speed.
          ARMOR
          Trailblazer 302
          X-TREME 12VS
          Spoolmatic 30A
          Millermatic 135
          Smith oxy set.
            Thank you armor, and yes your right, its metal core wire, tri mark metalloy, made by Hobart brothers
              Thank you both for your inputs, I have been MIG welding for only 2 years now and just recently discovered this forum. I believe this is going to be a great tool for me.
                .052
                It's a great sight. You can get some great information on here. But remember it's free so always do your homework.
                ARMOR
                Trailblazer 302
                X-TREME 12VS
                Spoolmatic 30A
                Millermatic 135
                Smith oxy set.
                  Thats pretty common in a shop...Bob
