Happened Again.. Tank Explosion Kills Welder
  • Happened Again.. Tank Explosion Kills Welder
    "Investigators told WBTV that Sheppard was welding on a fuel tank...."
    Eternal Vigilance is the price of safety... only takes one lapse to make for a bad day...
    http://www.wbtv.com/story/20640209/g...eppard-welding
    Hobby Welder for about 32 years
    Hobart 190 MIG with SpoolGun
    Hobart AirForce 700i Plasma Cutter
    Hornell Speedglas 9000X Helmet
    295A AC Buzzbox (what I learned on)
    Miller Bobcat 225, factory propane option, also serves as my emergency power generator
    Dandeman's Toy Page
    So sad...Bob
    Bob Wright
      Yes. Very Sad, our Prayers go out for this family!
      Remember, we can do this all our life But we may be only One Mistake away from leaving our family fatherless
        This is a sad thing to happen, I have been welding on tankers for a few years now and I have a 12" fan that sits outside the tanker with a 20' hose to purge the tank with fresh air before and while I weld.
          Not really the same thing portable welder.
          Hope your welding on a new tank that hasn't had any flammable a in it before.
          and wp2025 weldcraft torch
          Miller 125c plasma cutter
            sad
            i'm so sad for the love ones left behind.
            welding can be and is a dangerous trade and often not realized .
              jrscgsr, It is the same thing, Tankers for poope trucks, tankers from refineries that are part of the methonal process. My blower pumps out almost 3000 cfm to push any fumes out and to provide fresh air for breathing.
              So I'm replacing the air volume in the average tanker once a minute, I let it run for a minimum of a half hour before I even climb inside.
                Originally posted by Portable Welder View Post
                jrscgsr, Tankers for poope trucks, tankers from refineries that are part of the methonal process.
                Sounds like a good environment for using one of these...
                http://www.rkiinstruments.com/pages/...FQWnnQoduUMAag
                I'm sure they aren't cheap, but I've always found using the price of failure to be a good guide in determining how much I'm willing to spend on prevention..
                Dandeman's Toy Page
                  You can lead a horse to water but you can't make them drink. I am not a fan of welding on fuel tanks but I do it here and there. For ALL tanks I wash them out the best I can with water and degreaser if necessary. I then take a co2 welding bottle or a co2 fire extinguisher and purge it out. Dry ice is acceptable too. One problem is that (especially with gas tanks) even if you fill it with water there can still be gas embedded in the metal and it is VERY explosive then. Even old tanks from junk yards still have fumes embedded in the metal. When I was young I had to do some repairs on Wertgen milling machines and the fuel tanks are part of the frame. I don't know if this was good or bad but basically I was lead to believe it was safer(note: not claiming it WAS safe) to weld these tanks when they were full of diesel with the cap on but loose. You would run a quick 7018 downhill(usually) stringer to seal the crack and then clean it up and put a more sufficient weld on it. Purging with outside air isn't really a good alternative(even though it's a HUGE tank), you need to displace the oxygen with co2. Be safe guys, I see stupid all the time at my work and I swear people are just too TOUGH to do it right. I want to die when my body is nice and warn out....not before that. Dave
                    Those Eagle meters are the best way to tell without a shadow of a doubt. I retired from an oil refinery and i was the guy checking the tanks and pipes and signing off on the hot work/confined space permits saying it was safe to weld or go inside. Thats a load on a persons shoulders making sure everything is clear and signed because some contractors don't give a rats butt they just want to weld and leave. This way they are sure to leave walking anyways. And you have to treat every tank different no matter how many times you have done it. Just my thoughts...Bob
                    Bob Wright
