Cheater Glasses
  • Cheater Glasses
    I am a hobbiest/garage welder and I picked up a pair of +3 cheater glasses from CVS and used them for the first time this weekend.
    All I have to say is HOLY CRAP I can't believe what I can now see and what I was missing before. Magnification should be included standard in the helmet lenses.
    Things like being able to see the puddle melt down into the V on a T-joint and seeing the tungsten melt and drip when I had the amperage too high....amazing sights.
    You don't have to sell me. I use a #2 reading glassed over a #2 mag insert in the hood.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
      **** of a difference isn't it? I had the same experience. A whole new world opened up after I stuck a 1.5 in my Digital Elite.
      Miller 211 MVP
      Hobart StickMate LX 235
      Lincoln AC 225
      CutMaster 42
        Hi all, one thing you have to be carefull with, the lenses in off the shelf reading specs are both the same strength which means if your eyes are at different focuses due to eye deterioration from age or whatever, you'll get eye strain and at worst one eye will stop seeing the job and make the other eye work overtime.
        Before you indulge in any $5 reading specs, have your eyes tested for deterioration and if you want to go cheap you can always then get cheap reading specs from the bargain shops.
        Ian.
          I use a 2.5. I would say the glass lens is better than the plastic lens. Glass doesn't scratch when you need to clean it.
          Lincoln Vantage 400
          Trailblazer® 302 Air Pak™
          Miller Dynasty® 350
          Millermatic 350P Aluminum
          Millermatic® 252
          Syncrowave 351
          Lincoln LN-25 Pro
          Multimatic™ 200
          XR-Aluma Pro Gun
          Diversion™ 180
          Spectrum® 625 X-TREME™
          Thermal Dynamics® Cutmaster® 52
          Victor Oxy/Acetylene Set
