dye pen
  • dye pen
    Hey I'm wondering what an acceptable standard is for dye testing welds. Everything I've researched shows that you spray the dye on the weld to check for surface cracks. However is it acceptable or up to aws or asme code to dye the backside of the weld and spray the developer on the weld itself to see if the dye bleeds through the piece?
    dye pen
    You spray the dye onto the weld- let sit 10 minutes- wipe off really well then spray the developer on and wait 10-15 minutes and look for the dye to show up on the white developer. Never seen it done the other way though..
      Clean the weld very well
      Apply dye and let penetrate for 15min
      Wash off dye with water and rag/towel
      Spray on developer and observe. No wait time is necessary here
      Because the dye has no surface tension, it gets into tiny spots that the rinsing water can't.
        No it's not acceptable under those codes. For several reasons.
        How in the world would you discover surface cracks by spraying the penetrant on the "back" of the weld? Might as well spray it on the ground a quarter mile away.
        JT
          dye pen
          Ok thanks guys. The answers you gave me back up what I've researched.
            miller ac
            Hey I'm considering buying one of the ac packs for your welding hood off the miller site. Does anyone know if they are worth the 300 bucks?
              when we check tanks we will spray dye on the inside and developer on the outside (leave for a few hours before checking). this does not meet any codes but will tell you if there is a leak and will hold fluid. this is done buy many companies to check tanks and also worked with some companies that fog dye inside and test the out side to pass for the API certs. so yes this will work to look for leaks in a tank. if you are looking for cracks in the weld zone then use as described on the can.
              trail blazer 302
              hypertherm plasma
              millermatic 251
              high feq. arc starter
              suit case (extreme 12vs)
              o/a torches
              way to many other tools to list
                if coating/painting is not an issue you can also use diesel pen. it is an acceptable test on large storage tanks for the floor to shell weld
