Section 5-9 Output control in the manual tells you all of that
Application: Use Remote Trigger (Stan- dard) when the operator desires to use a foot pedal or finger amperage control (see Section 6-3A).
. When a foot or finger remote current control is connected to the welding power source, initial amps, initial slope, final slope, and final amps are
controlled at the remote control, not at the welding power source.
. If On/Off only type trigger is used, it must be a maintained switch. All Se- quencer functions become active, and must be set by the operator.
RMT 2T HOLD
Application: Use Remote Trigger Hold (2T) when long extended welds are made. Remote Trigger Hold (2T) can help to re- duce operator fatigue.
If a foot or finger current control is con- nected to the welding power source, only
trigger input is functional (see Section 6-3B).
Section 5-11 discusses Sequencer function and the first section informs you what happens when you use a remote in standard
Sequencing is available only while using the TIG process, but is dis- abled if a remote foot or finger cur- rent control is connected to the Re- mote receptacle while in the RMT STD mode. Sequencer parameters cannot be selected if the Stick pro- cess (see Section 5-8) is active.
RMT 2T HOLD
