got a nooby question here. just started stick welding at school, and i cannot make a stright weld to save my life LOL. i used soap stone to make a line, but it disappears when i start welding. is there another way so i can see the line?
can't make a stright weld
Soap stone works but u need to develop hand eye. To help that use two hands, one to hold stinger other to guide & keep steady. Also at 1st u can lay down a piece of metal as guide to slide your guide hand along. Make a dry run with hood up to get feel of bead then run it.
As with most things practice refines, practice, practice, practice. It will come in time.
Get old stinger or buy cheap one & put pencil in place of rod, practice in spare time on paper to develop skill.
Try grinding a shallow groove in the base metal to follow, it will be more like filling a seam than just trying to run a bead on flat stock.Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
Also, don't be too proud to refuse using a cheater magnification lens.
I use a 1.5 X most of the time and if the amps are really low I'll put on my reading glasses as well.
Regards Andrew from Oz.We are tig welders, gravity doesn't worry us.
Miller Dynasty 350 Tig.
OTC AVP300 AC/DC 300 amp hybrid wave Tig. (now retired)
Kemppi MLS 2300 230amp AC/DC Tig for home with all the bells and whistles.
