tools for an apprentice welder fabricator?
  • tools for an apprentice welder fabricator?
    What tools should one own as an apprentice fabricator welder?
    I work with medium/heavy steel and rarely with thin steel (never less than 2mm) I have ball peen, lump hammers
    Various burning nozzles,
    Scribes
    Centre punches
    A trammel
    Steel rule
    16ft tape
    Files flat and round
    Chisels
    Punches
    Screwdrivers
    Squares (regular and combi)
    And a hitachi 9" grinder.
    Is there anything that any of you can suggest will help make life easier?
    Cori
    If you ain't burnin' you ain't learnin'
    Scribes
    Centre punches
    A trammel
    Steel rule
    16ft tape
    Chisels
    Punches
    Screwdrivers
    Cori
    2 At least 25' tape preferably 30'.
    4-1/2" angle grinder.
    Levels magnetic 8" & 48" two each.
    Framing square & large adjustable t-square.
    Chalk line for large layouts.
    Plum bob.
    Pair of Collapsible pipe stands.
    On/off 90° powered magnets. Helps while tacking & layouts.
    That's off the top of my head.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
      Nice stabila levels, nice angle finders, good comfortable ear protection to name some of my favorite day to day items.
        Should be supplied by your work
          Not everywhere.
          My previous employer had us (welders) supply all our own tools.
          Which I didn't mind.
          But ! if your tools get damaged or worn -the employer does need to replace them.
          & 1 other item I just can't do with out
          are Bessy clamps. Try to build your set in pairs. Their expensive but a must have tool.
          Millermatic 211
          Spoolmate 100
          Miller 130xp
          2. 4-1/2" grinders
          1. 9" grinder
          14" Makita chop saw
            Vice grip clamps, for small stuff. Soap stone holder, compass to fit round soap stones, hood, chipping hammer,ss wire brush , welding jacket and tig finger, sold by weldingtipsandtricks.conm
              Never worked somewhere that didnt provide all the safety gear, grinders, & clamps. I use calipers alot. Also took 2 pieces of angle about 2" long & welded flat bar on the point of the angle & then put a half moon bead of weld on the flat bar. Helps with using pipe clamps on square tubing when trying to square up parts. Also have a 6" scale. If you have to provide your own grinders a nice die grinder & dynabrade belt sander are nice too.
              Miller Trailblazer 302
              Miller Passport Plus
              Miller Spoolmate 100
              Milwaukee 4 1/2" Angle Grinder
              Milwaukee Sawzall
              Miller Elite Inferno Hood
              Miller Diversion 180
              Miller Digital Elite Vintage Hood
              Miller Camo Digital Elite Hood
                I've never worked anywhere that didn't supply the tools and would buy you any tool you needed to do the work
                  Ask them what they expect... so you don't buy stuff you don't have to......unless you're RICH!
                  Miller 30-A Spoolgun
                  Miller WC-115-A
                  Miller Spectrum 300
                    i use two 4 1/2" angle grinders a lot. One has a flap disk the other a grinding wheel or cut disk. Heck i could use a 3rd on but just to much stuff hanging on my welding cart.........Fireman Bill
                    HH 210MVP
                    Spoolrunner 100
                    Powercraft AC buzz box
                    Lotas LTP5000D plasma
                    Victor Oxy/Acet
                    30 ton press
                    A few brand name tools
                    Lots of no name tools
                    A wife to worry me
                    and 4 dogs to supervise me
                      Does anyone use carver clamps?
                        (2) 1 1/4" spuds
                        (1) adjustable spud
                        (1) 1 1/8" spud
                        (2) sleever bars
                        (1) chipping hammer ( mine is drywall hammer with nuts welded in the flat side. I have tips i can change out
                        40' tape
                        Ratchet spud 1/2" drive
                        3/4" drive ratchet
                        2 bolt bags
                        Scabbard
                        Sleever bar holder
                        Squares
                        Clamps
                        Just to name a few...don't forget a welding hood
                          -100 feet of tring.
                          -allen wrenches up to 3/8"
                          -allen wrenches up to 10mm.
                          - toolbox that is lockable for all the tools along with room for expansion
                          Just a few suggestions that I have.
                          Byron
                            What is tring?
                            I googled it and it said its a small market town in Hertfordshier, England.
                              cori_southwales,
                              Here is what I have found to be very useful.
                              I use several as cheap, almost disposable tooling.
                              By this I mean that I can hold parts with them and if necessary, I can weld on pieces to create a simple, inexpensive, and quick custom fixture.
                              If I want to "reclaim" it after a project, I cut off the extra pieces and grind it somewhat smooth.
                              If it is too far gone, I can still save some parts of it for another project.
                              It sits flat on my weld table and I don't mind if I mess it up while welding.
                              Here in the states, one can be purchased for about $10 US.
