I have a 180 SD and have quite a few questions, all concerning aluminum. First, no matter where my ground is, how clean the material is, my arc starts are extremely eradic. (sp?) I use pure electrodes, and have found that the best way to select Tungsten size is to use the smallest tungsten that doesn't "spit" the tip. (or create a ball that's too large) I've tried flooring the pedal instantly and ramping power up slowly, but nothing has helped. The HF is working, and after the arc starts, it runs fine.
Next question concerns material choice. I'm planning on building aluminum sumps, tanks, pans and valve covers, and from everything I've read, 3003 H-14 seems to be the alloy of choice, using 1100 filler. To weld 6061 bungs, fittings and brackets to the 3003, it's suggested to use 5356 filler. Does this sound about right? My AWS filler chart supports these filler choices (for ductility) but I'm allways looking for a second opinion.
I have another concern about alloys... I have a friend who is going to bring me a Moon style spun aluminum fuel cell, and I'll be heavily modifiying it. The ends of these cells are 1100, while the bodies are 3004. Can anyone tell me what the difference between 3003 and 3004 is? Does the filler choice remain the same?
Last question. Well, more of a request. My butt and lap joints are looking ok, but fillet welds are lacking. I've attached some pictures of a few lap welds and a fillet. Please tell me what I'm doing wrong!! I've read that you can use 2% With a blunted point for fillets to get a smaller bead with more control. I haven't tried it yet, but what do you think?
Thanks in advance!
Matt
P.S. Please forgive me if the pictures don't work... I'm computer illiterate!
Thanks in advance!
Matt
