Rusty pipe flange. Need to separate
  • Rusty pipe flange. Need to separate
    I'm trying to redo the pipe on my exhaust for my truck. In order to take only the section off I need welded, there's a flange right after the catalytic converter that I should be able to unbolt. Only problem is it is so rusted that I can't get it to come apart. Any ideas?
    Pb blaster or wd40 and let it sit? How fast does it need to come off? Can you heat up some part of it to break it loose?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
      BFH---works every time.
        Heat wrench...BFH...hacksaw...O/A torch
          If your just talking about the bolts then get new ones & cut off the old ones. If you have already done that & the flanges still won't seperate then you can try heating them with a torch & hitting with a hammer. Also maybe there is a spot you can get a chisel started between the flanges to force them apart.
          MM250
          Trailblazer 250g
          22a feeder
          Lincoln ac/dc 225
          MM200 black face
          Lown 1/8x 36" power roller
          Arco roto-phase model M
          Vectrax 7x12 band saw
          Miller spectrum 875
          30a spoolgun w/wc-24
          RCCS-14
            Ok. I think I'm gonna try the chisel since I cut the bolts and it's still attached. I don't really have access to a hot enough torch so thats out the window.
              If inner pipe is trash denting it inwards will help breaking the rust. Heat from a propane torch would be a big help. Either way wd-40 and tapping it with a hammer will help too. If you spray it before heating it watch you eyebrows.
              Joe
              [email protected]
                Kroil
                  Get tools
                  Invest in some Kroil Oil and O&A torch. Do you have an air hammer? cut off a bit or buy a hammer bit and vibrate it off
                  Never Satisfied
                  Millermatic 211
                  Maxstar 150STL
                  Metabos
                  Kennedy Maintenance Pro Full
                  Makita Cordless 18v Li-Ion
                  Stihl TS 420
                  [email protected]
                    I do lot of custom exhaust work please post what year model motor and ect ect ect i can tell you a easy way to fix it u might not need to worrie about the flange behind the cat post it up and will advise
