Dialarc HF remote contactor not working.
  • Dialarc HF remote contactor not working.
    Went to do some tig welding on a pocket knife for a neighbor. Remote contactor worked one time and quit Checked the plug on the pedal and it is working . Any suggestions ? I am pretty sure its a 1977 model .
    No Serial#, no can help......
      Hh012516
        If the microswitch in the pedal is ok, you likely have a stuck CR3 relay in the machine. There are 3 relays, CR3 is the one furthest away from the square bridge. Give it a tap with a screw driver end, or replace it.
          Thanks. I will check it out.
            I tried tapping on the relay while stepping on the pedal and it still did not want to close on its own. I found a new relay on ebay and bought it. Looks like they are hard to come by. ????
              Thank You cruizer $25.00 fix
