Please help - how do you preheat aluminum for mig ?????
  • Please help - how do you preheat aluminum for mig ?????
    Would like some advice on preheating aluminum bar.
    Tack welding 1/4 inch aluminum bar for tack weld at T joint.
    How would I preheat for mig welding with a passport plus using spool gun
    an argon.
    Anyone have experience welding aluminum bar with mig ?
    That thin you really don't need a preheat just turn it up and go.
      35 years worth. I use a propane torch...Bob
        Hi Bob
        Hi Bob
        I guess I should have asked first -
        Do I need to preheat the 1/4 inch aluminum bar ?
        using passportplus/spoolgun/110.
        I've been told it's not possible as it will be too cold,
        then told it would melt too fast.
        Thanks for reply,
        Stu
          Don't know about your passport as i have never used one but you will just have to try a couple of small chunks of what you will be doing. That would be the best way. Just my thoughts...Bob
            Even with heat, you are pushing the passport at 110. It all depends on how practice pieces work out.
              I had to weld 7" x 7" x 8' chunks of aluminum to 4x4x1/4" TS and used a propane rose bud and a temp stick, I brought it up to 450 degrees before welding it with my push pull set up.
                Try a test piece first. If the bead profile is too high, then preheat and try it.
                Some things need preheat just to get the bead to flow out decent.
                I like to use the AO torch and smoke it (with the soot) myself. Then heat until smoke is gone. Works good for me.
                Miller 30-A Spoolgun
                Miller WC-115-A
                Miller Spectrum 300
                  Mapp gas burns hotter. Costs more but works better.
                    Make sure if you are preheating or welding to insulate it, if you are welding on a steel table, the steel really sucks the heat out of aluminum and makes it difficult to weld
                      Thank you
                      Thanks - the advice and tips here are really helpful,
                      appreciate your time replying.
                      Stu
