Bobcat 250
  • Bobcat 250
    I have a newer Bobcat 250 at work that has everyone stumped. It is the only gas welder we have. I am a diesel mechanic which is good because we have 20 diesel welders but only one gas SN# MA180071h . The motor doesn't run it cranks, sparks, and I have fuel after the fuel pump is there something I am missing? I can get it to fire and run for a moment on starting fluid. if i poor gas in the carburetor it will sputter and run for a minuet then die. The carburetor is clean. The motor is a Kohler SN# 4013403941. Is there some kind of electric shut off or something. Thank you in advance.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    What about the low oil shut off switch, could this be the culprit?
    Nick
      I know it has oil but how does the switch work? Stop spark? because I have spark? How would I test it?
      Never Satisfied
      Millermatic 211
      Maxstar 150STL
      Metabos
      Stihl TS 420
      Timfrank88@live.com
        My honda on my compressor was doing the same thing. I thought my carb was clean. I was wrong. Took carb apart, pulled float needle and ran a piece of wire ( from a twist tie off a loaf of bread ) thru the tube . Put back together and it fired up first pull. All this done after i sprayed a whole can of good carb cleaner thru it and it still wouldn't run. If you are getting gas to the bowl that may be your problem
          Tim,
          I remember reading on the forum that if the switch failed it could cause the unit not to start. I could be wrong, but I seem to remember something like that. Maybe we could do a search. I am sure tomorrow when Cruizer or Duane sees this you will get your answer.
          Nick
            Thanks Nick yea I'm hoping its something like that. I am not a small engine guy. I don't think it's the carburetor one of my coworkers cleaned it. I didn't take the carb apart myself but he is pretty reliable. I forgot to mention the welder has less than 125 hours on it.
            Never Satisfied
            Millermatic 211
            Maxstar 150STL
            Metabos
            Stihl TS 420
            Timfrank88@live.com
              Try bypassing the low oil switch.
              MM250
              Trailblazer 250g
              22a feeder
              Lincoln ac/dc 225
              MM200 black face
              Lown 1/8x 36" power roller
              Arco roto-phase model M
              Vectrax 7x12 band saw
              Miller spectrum 875
              30a spoolgun w/wc-24
              RCCS-14
                Just behind the carb sits the fuel shutdown solenoid, perhaps the wire that runs it came off.
                Nothing to do with oil pressure switch, as you wouln't get any spark
                  Engine won't start
                  You can go to opeengines.com and download the manual for that engine or look at the parts breakdown for free, they are a online kolher dealer.
                    The fuel cut-off solenoid ( already mentioned by Cruizer) will sometimes gum up and ethanol will corrode the solenoid stem.
                    Easy to clean if gummed up and easy to replace if corroded.
                    If gummed up, sometimes you can tap on the solenoid while the engine is being cranked and get it unstuck.
                    Griff
                      Ok I'm waiting on a new solenoid ill update if anything changes. Some dumbasss put the cover back on the welder yesterday so I had to pull it again.
                      Never Satisfied
                      Millermatic 211
                      Maxstar 150STL
                      Metabos
                      Stihl TS 420
                      Timfrank88@live.com
                        Bobcat 250
                        Sorry for the long delay in response this project got set on the back burner. I took the cover off the back of the welder and pulled the air filter housing tapped on the solenoid with a 8oz dead blow hammer turned the ignition boom fired right up. I didn't replace the solenoid I have a spare and if it acts up again ill replace it. Thank you all for the help easy fix.
                        Never Satisfied
                        Millermatic 211
                        Maxstar 150STL
                        Metabos
                        Stihl TS 420
                        Timfrank88@live.com
