I know this has been covered but id rather be safe than sorry. Il be running a mm200 off of a dryer plug, 4 prong with 2 straight side posts one l shaped and a circle, to the welder plug. Ive seen everything from having to spending 80 for the wire to taking a dryer plug cable and capping the neutral wire and hooking rest to a welder receptacle.. ive also considered changing the plug on my machine to a 4 prong. Which is better? Any advice? Also i know doing this isnt ideal but I live in a rental house and cant wire in a dedicated 220v 50a breaker
3 to 4 prong
Check the wire gauge running to that dryer plug. If it will support the amp load for your welder, go down to the big box store and but a couple of feet of SO cord, four prong plug to match the dryer receptacle and a receptacle to match your welder plug and wire up a pigtail converter. Fairly cheap conversion and you'll be able to leave both the welder and the dryer receptacle as is. If you need extra cord length to make the run to the welder, add that in.Miller 251...sold the spoolgun to DiverBill.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
There isn't a lowes for about 35 mins from me, hd is going to get the wire from another store for me. Then i have my regulator/gas hose on order should ship monday and finally the tank which i gotta find a way to get from where i live to the lws which is 1 hr away with traffic and closes an hour after i get out of school..
Originally posted by ZJones1994 View Postthe tank which i gotta find a way to get from where i live to the lws which is 1 hr away with traffic and closes an hour after i get out of school..
Good luck with the welder.
Meltedmetal
PS-Beware the transport regulations. Around they shippers won't let you load if it is not in compliance because they get fined too if you get caught. This may or may not apply where you are.
