Mm175
  • elvis
    started a topic Mm175
    Mm175
    Looking at a millermatic 175 on the local CL. The seller says that it works great but when the voltage is increased the wire speed increases too. Are these two knobs connected? What about repairs. is it worth risking some money on this machine? Asking price is $500.
  • elvis
    Given the sellers comments about the problem i don think so. Goin to swing by airgas and see if they remember what they diagnosed. I need a bottle of argon anyway.
  • sdwelder
    Mm175
    Weird that you cant get the WIRE speed LOW enough. (I only made those words bold to bring attention to them. Not to question the symptoms.) I tacked a 1/4 20 nut to a piece of 22 ga today with my MM211. .30 wire normally not a problem, but i was running off a super thin extension cord. (50' long) I was WAYYYYY below the recomended wire speed to pull this off because the machine was just not getting any power. I know its not the machine. It runs like a raped ape. Anyway. Any chance the machine was choked out?
  • elvis
    stuff
    .023 and .035 w/ c25 mix. I know the 23 wire was a little small but both wires didn't react right.
  • cruizer
    And what wire and gas are you trying to weld with
  • elvis
    eh, its OK and definitely not right
    So I got to use the welder today. It welded fine on 1/8" material, the bead Wouldn't lay down the way I like. When i cranked the voltage to 11 (ha ha, it was actually on the 10 mark) I couldn't get the wire to go slow enough. Apparently the lws prescribed a new control board of some sort. At some point this dude installed a spool gun switch. Could that have screwed this up? Also, any hazards if I open it up and remove the spool gun switch? Any capacitors that will hold electricity?
  • elvis
    Called the seller
    To get a chance to go check it out. Seems like a good price to me. I use one of these at work pretty regularly. I wish it had more power, but I have a 8vs to get a little more amperage. I have never paid attention to wire speed increases as i change voltage settings. I don't even think about what I'm setting anymore, I just look at what I'm about to weld, set the knobs and go!
  • Broccoli1
    Miller uses wire speed tracking
    Wire speed tracking is where the wire speed increases or decreases as VOLTAGE control is increased or decreased in order to help the operator stay within the weld parameters when making voltage changes.
  • cruizer
    Yes the Voltage and Wire speed depend on one another, UP the voltage and wire speed while still adjustable will increase. For $500, its a good deal for sure.
