24 gauge stainless help
  • 24 gauge stainless help
    Does anyone have any ideas about how to weld a piece of 24 gauge SS? This is a long piece of trim from a classic car. It needs about a 1/4 inch weld.
    I tried using a Dynasty 350 on 5 amps. Too hot when the arc starts and not hot enough once it stabilizes. Tried using heat sinks to keep the heat away from the trim. Tried pulse. No luck.
    Any suggestions?
    Lincoln Vantage 400
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Thermal Dynamics® Cutmaster® 52
    Victor Oxy/Acetylene Set
    24 ga. SS
    Any suggestions?
    No luck as in?? fusion, or melt thru, or both?
    Type of joint? pics always help
    You need to use sample 24 ga. SS to establish parameters
    Firing off on the filler-not the parent is a must
    Pulsing a 3-5 cps for manual TIG helps on most thin SS,
    then playing with the peak and background settings
    .040 or .020 electrode
    there's ways to tone down the dynasty's rather aggressive arc start
    (I didn't like that-at all, at first--but now I'm getting more comfortable
    with it--on 24 ga. SS headlight rings. It's not as violent as it first
    appears to be--it's just different from a nice, soft, start. )
    filler size dependent on the mystery joint, maybe .024 or .030
    The older cars may have used variations of 304 or something else.
    On old ford SS radiator surrounds, 308 filler has worked
    Solar flux on the backside is needed-or tight fitting chill block
    dave powelson
    Senior Member
      Thanks Dave. It was a butt joint with 2 cps on pulse and a 1/16 electrode. Melt through on initial arc start was the problem. I didn't have any other 24 ga to set up the machine and practice with. No pics either.
      Starting the arc on the filler sounds like a good tip.
      Lincoln Vantage 400
      Miller Dynasty® 350
      Millermatic® 252
      Syncrowave 351
      Lincoln LN-25 Pro
      Multimatic™ 200
      XR-Aluma Pro Gun
      Diversion™ 180
        No filler an option? Turn your amps up a bit and just mash your pedal all the way down and let it up right away. Stainless is tough stuff and can usually be fused. Just a thought
          I used to occasionally weld 24ga. S.S. for counter tops. I would use shielding gas on the back of the weld sometimes by piping the gas into a manifold constructed of aluminum insulation tape on the back of the 24ga. I would also start the arc on the filler. I used .030 S.S. mig wire cut into lengths for filler rod because it was thin and worked well with low amps.
            dynasty 350 DC start parameters
            Any suggestions?
            In addition to dialing down the amps on the 350-you need to go in
            the sub menu to select electrode size, etc. It tailors the start to the electrode size selected.
              I use an old AC-DC transformer stick welder with an air cooled torch, small tungsten,scratch start.....First wire the primary voltage to 110 volts (do this at the cord cap) Use a starter plate or start the arc on the rod ....You can wire the old transformer boxes up like this as they don't have any electronics inside, only a transformer....The fan may have to be disconnected......
                S S has different colors when you polish it you can see the welds I used 308 on some 59 Chevy trim it was very close. I also started the arc on the filler then file it sad and polish it.
                MM140 AS
                375 Xstream
                Diversion 180
                  Just a thought, but can't you solder it? Depending on where the joint is, you might not ever get a weld on it. I have welded on cars from every angle so it is hard to picture just where this weld is.
                  Depending on if this can help or not, but needs 2 people to do this. I made a jig for welding very thin s/s that used a 1/2" thick copper backing with a 3/16" hole bored through it that I connected water lines to that allowed water to cool the copper faster then the low amps could input on it. If this is possible, you would need to increase your amps to say 15 because 5 amps would get sucked away by water.
                  24 ga doesn't have enough metal to fuse unless a real good joint is made.
