Miller syncrowave 300 woes
  • user name:
    started a topic Miller syncrowave 300 woes
    I picked up 3 of these units not too long ago. I planned on keeping one for myself. Anyways I have one unit that is not giving any output voltage... Ive set it up for stick welding and cannot get it to run.
    The unit powers on but makes some sort of buzzer noise (maybe a contactor issue?) for about 3 seconds then the noise stops. the fan comes on and the power light comes on.... anyways I made some videos so someone may recognize the issue!?
    http://s530.beta.photobucket.com/use...01305.mp4.html
    http://s530.beta.photobucket.com/use...65822.mp4.html
    this is one working correctly with all the similar settings and leads anyways its 1/16" 7014 rod lol...
  • user name:
    Ok guys got it all figured out preciate ya 7A749...
    the buzzing ended up being the cooling line solenoid but it was not the source of the absent voltage output. That ended up being the PC1 which was loose enough to not make full contact in the terminal. Unit is working flawlessly now. thanks everyone for the help!
  • user name:
    Originally posted by cruizer View Post
    IS it the source of the buzzing or not....
    Cruizer I will know tonight when I get off work if the sound is actually coming from this relay or not. I will report my findings here. thanks for the help guys.
  • cruizer
  • user name:
    Originally posted by Dipsomaniac View Post
    Well, I would take the relay out, disassemble, refurbish the contacts and of course blow all foreign material out of this unit, IF it is the source of the "buzzing".
    thank you sir, I imagine I would want to put my multimeter on it to make sure its getting 24vdc as well right?
  • Dipsomaniac
    Originally posted by user name: View Post
    so should I just blast this out with compressed air? I cant find directions in the tech manual on how to test this relay? How can I test it to find out if its bad?
  • user name:
  • Dipsomaniac
    Is this it? sorry about my horrid paint skills, ha.
    That does look like CR-1...
  • user name:
    I think if you locate Relays CR1 and CR2 you will find one of them (more than likely CR1) is your "buzzer"...
    Take a look in the Resource section on this site for your machine manual and wiring schematics and you will also find the location of those two relays in the parts section of the manual. They should be very close to one another.
    Good luck!
    Well, your vids never worked for me anyways. And since no tech is there to look at it, all we cn do is throw out suggestions. You want it fixed take it to a repair center. Could be a relay, could be a failed contactor. If you have zero electrical knowledge, us suggesting things is is little useless. However if you know someone handy in such things. Have him post here then we can easily figure it out.
    I'll get it figured out I think. I do appreciate your help though buddy.
  • cruizer
    I put a video up... why would you ask me "if its just a buzz"? I am not a sound technician so I have no idea how to describe sounds. did you see the video I linked, if so is that just a buzz that would cease after a few seconds and still leave me with a dead welder? for all i know it could be a gobbledy gook humming sound. Im not quite sure what the "coil part" is either... there is a ton of coil parts in this massive welder.
  • Dipsomaniac
    ... Im not quite sure what the "coil part" is either... there is a ton of coil parts in this massive welder.
    Good luck!
  • user name:
    Didn't I already answer your question, how many varifications do you need.....
  • cruizer
  • user name:
    ? anyone
  • user name:
    If its a buzz its just a contactor. Usually dust in the shunts. Just take the coil part of it apart and clean it.
    could that be the reason im not getting any voltage output? also would that explain why its a loud buzz then after about 3 seconds it stops?
