We just added a tigmate 3 to and old syncrowave 250 at work. I was busy with another project when it came in and someone else installed it and hooked everything up. Yesterday was the first time I have tigged anything since. Well in a hurry and getting late in the day I flipped the welder power on, started to weld and burnt a hole in the hose. Everywere I have ever welded with a tig cooler on the welder, the cooler was left on and pluged into the switched outlet on the welder. The 250 has a switched outlet on it and the cooler is pluged into it. I have checked all the manuals and cannot find anything saying you can leave the cooler power on or not to. Which way should it be done?
Tig Cooler On or Off
Yes, leave the switch on the coolmate on. That way it activates automatically when you switch on the welder. Most all other coolers don't have a switch.
Helps to verify coolant flow every time you start up anyway. Put a piece of tape over the switch in on position.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
Originally posted by Diverdude View PostI thought so, I never saw a switch on one before this. Only makes since, why else would they put a switched outlet on the welder. ThanksNothing welded, Nothing gained
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
