Originally posted by weldonwelding
why even build a 20% duty cycle machine?!
Originally posted by Dipsomaniac:296575Originally posted by weldonweldingI usually wouldnt post something on this forum if i didnt know the facts. This is a perfect example of why. Thanks for viewing
Originally posted by weldonweldingPeople that actually have welding to do. This machine is definetly not the "homeowners" machine. The price tag proves that. Thats not my point though. The point is this machine is 120v 140amp 100% duty cycle. My friend that owns the one i used had to install a separate receptacle for it... because of it being 30amp.
LOL...You could get a Millermatic 252 for less money and have a bigger machine (150amps @100% duty cycle) for those of us that use 240VAC...LOL
Originally posted by Dipsomaniac:296577Originally posted by weldonweldingPeople that actually have welding to do. This machine is definetly not the "homeowners" machine. The price tag proves that. Thats not my point though. The point is this machine is 120v 140amp 100% duty cycle. My friend that owns the one i used had to install a separate receptacle for it... because of it being 30amp.
Originally posted by weldonwelding:296580Originally posted by Dipsomaniac:296577Originally posted by weldonweldingPeople that actually have welding to do. This machine is definetly not the "homeowners" machine. The price tag proves that. Thats not my point though. The point is this machine is 120v 140amp 100% duty cycle. My friend that owns the one i used had to install a separate receptacle for it... because of it being 30amp.
Originally posted by Dipsomaniac View PostDo you see the issue with this machine? How many people that only have 120VAC can supply 30amps through their outlets?Originally posted by weldonwelding View PostPeople that actually have welding to do. This machine is definetly not the "homeowners" machine. The price tag proves that. Thats not my point though. The point is this machine is 120v 140amp 100% duty cycle. My friend that owns the one i used had to install a separate receptacle for it... because of it being 30amp.Millermatic Passport Plus
Millermatic 350P with Python
XMT 304 /w S-64 feeder and 12VS
Dynasty 300 DX
Thermal Arc 400 MST
Premier Power Welder for my trail junk.
Ill take a miller 211 over this machine anyday. Its like having a jet but no runway useless..
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
Originally posted by nfinch86 View Post100% Duty Cycle @ what amperage ?
I've never seen any mig welder with 100% duty cycle !
..........Norm
Need 150 Amps at 100% duty cycle?
Miller makes that machine it is called the Millermatic 252
Need 130 Amps at 100% duty cycle?
Miller makes that machine, it is called the Millermatic 212
There are plenty of 100% duty cycle welders out there, just not 100% at their max output is all.
This whole thread is way off point.... no you dont need 100% duty with a 250 amp machine... but with the 140 amp machine you do. I overheat my 180 quite a bit and its not even turned halfway up. Overall miller doesnt even make a machine to compare to the muscle mig, a 110v machine with a feeder and features like spot and stitch are made for more of a body shop or someone without 220v capability. With the millermatic 140 u may be able to weld 14ga continuous but with the snap on you can weld 1/4 continuous. If any of you are welders you will comprehend.... if not so be it.
I know you didn't ask but my thought would be that Miller makes their machines geared to the end user. A 110v mig is mostly bought by hobbiests or body shop/guys who would never need 100% duty cycle. If they needed something more robust they could step up to a larger machine. I assume this also helps keep the cost lower.
I'm glad you liked the Snap-on machine. I have not heard many good things about them especially when you need repairs or parts.
I do understand what your saying.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
I actually don't understand the point of the thread.
You state "Why even make a 20% duty cycle machine?"
The answer is obvious- not everyone needs a 100% 140amp 120v machine that sells for $2,700.00
It is pretty much the same with any product:
Computers- how fast do you need to process?
Cameras- how many frame per sec do you need, how many MegaPixel do you need to capture
Vehicles: How much Torque/HP do you need?
so and so on.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
I can't imagine a body shop that wouldn't have 240vac for a welder. That would mean they could only use 120vac air compressors for all the air tools they may use. Not much of a body shop in my opinion not to mention an industrial enviroment needing 100% duty cycle and only 120vac to the building.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
