MillerMatic 200 + SpoolMate 100
  • MillerMatic 200 + SpoolMate 100
    Have use this gun frequently, with a 211...but never with steel wire (NOT flux-core), always with aluminum.
    Will this gun run steel wire with the 200?
    And can I use ARGON...instead of CO2, since I have Argon in abundance?
    Steel works fine with any spoolgun, though if your a welder, you should know better on the Argon issue
      I assume you mean Argon Mix ( 75-25 ) Not straight Argon !
      Pure Argon is for welding aluminum !
      ...........Norm
        I think the bigger question is how are you going to run the Spoolmate 100 on a MM200. Just my thoughts...Bob
          About the only way would be coupled to an SGA 100 with a modified control cable plug to fit the MM200 4 or 14-pin spoolgun control receptacle depending on its generation.
          Syncrowave 180 SD
          *HF-251D-1
          *WC-1S & Spoolmatic 1
          PakMaster 100XL
          Marquette "Star Jet" 21-110
            will the spoolmate 100 direct conect to my millermatic 200 serial number JF946510
            my millermatic has a four pin spot for a spoolgun
              Correct but not all Spoolguns work on all machines, you have to have the correct spoolgun
              Ed Conley
              MM252
              MM211
              Passport Plus w/Spool Gun
              TA185
              Miller 125c Plasma 120v
              O/A set
              SO 2020 Bender
              You can call me Bacchus
