advice on portable plasma
  • advice on portable plasma
    Ok I've been looking at a few plasmas
    Id like to be able to cut 3/8"
    And have 120/220 option open
    Millers 375 xtreme vs hypertherms 30.so far I like.
    What's the best deal In the long run.
    Both are sold locally. & is there any other
    Brand. I should consider. Thank for the advice.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    (Retapped to fit regular mig tips)
    Work better & less parts to stock.
    Miller 130xp
    T/A Dragster 85 (portability 11 pounds)
    Oxygen/Acetylene torch set 50'
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Torch on the 375 is hardwired... 30 is not...
      Personally, if you can get away with the 230 power, a Thermadyne 52 is a fine machine, 1 year longer warranty and haven't had ANY problems with them.
      If you need both 120 & 230, the Thermadyne 42 is your best bet
        I have personally used both the 375, and the Hypertherm 30! I chose the Hypertherm 30 and do not regret it. It is very portable, cuts extremely well, I really liked their tour of the plant on the web.
        Can use on 115/230, what really sold me was the Hypertherm was displayed with all consumables at all three of my local welding supply stores, Miller at only one (not Millers Fault)
        Everything I have cut with the 30 has been from 55 gallon drums to 3/8ths and it was flawless.
        I'm sure the 375 performs just as well! I just chose the Hypertherm and have been very happy with it. I know this post is ambiguous, but I'm a big Miller fan and do not want to critic something I have only used a couple of times!!
        Bottom line the Hypertherm is a great unit, and I feel you can't go wrong either way. But I would really take a look at the Powermax 30 before you decide!!!
          Cutting 3/8 cleanly with any machine running on 120v will be a tall task.
          The hypertherm 30 does not use the new durramax style torch. This new torch is a great upgrade but is available on only the larger units from Hypertherm.
          I would by a Hypertherm, Thermal Dynamics or Esab plasma cutter before I bought a Miller. The hypetherm units will be the most expensive in their class.
          I have the TD cutmaster 52 (60 amp), it has been a good machine. The TD cutmaster 42 is 40 amp (on 230v) and will run on 120v and 230v. The TD units also have a 4 yr warranty as stated. All the others have a 3 yr warranty.
          Lincoln Idealarc 250
          Miller Bobcat 250
          Thermal Arc Hefty 2 feeder
          Thermal Dynamics Cutmaster 52
          Torchmate CNC table
            In my opinion Hypertherm is at the top of it's game, for many years now they have produced some of the most efficient and trouble free plasma cutters I have ever used. Thermal has come on strong in the last few years and has improved quality and Miller is pushing them along with ESAB. Look at each's performance chart for travel speeds and capacity. Then pick the one that gives you what you need at the best price.
              Either the Hyper or Miller will only cut 3/16 on 110
              252 Miller Mig
              180 Synchrowave
              R - 45 Milling Machine
              Kingston 1100 Lathe
              Miller 2050 Plasma Cutter
                Thanks I'm going to get myself a hypertherm.
                Millermatic 211
                Spoolmate 100
                Miller 130xp
                2. 4-1/2" grinders
                1. 9" grinder
                14" Makita chop saw
                  I haven't had any problems with my Miller 625 X-Treme. But the way everybody talks about Hypertherm makes me wish I got one of those instead.
                  Lincoln Vantage 400
                  Trailblazer® 302 Air Pak™
                  Miller Dynasty® 350
                  Millermatic 350P Aluminum
                  Millermatic® 252
                  Syncrowave 351
                  Lincoln LN-25 Pro
                  Multimatic™ 200
                  XR-Aluma Pro Gun
                  Diversion™ 180
                  Spectrum® 625 X-TREME™
                  Thermal Dynamics® Cutmaster® 52
                  Victor Oxy/Acetylene Set
                    Another vote for the Hypertherm. Here's a site that may help.
                    http://weldingweb.com/forumdisplay.php?f=57
                      Got a Hypertherm 1250 for 10yrs now,not a single problem.
                      BB402D
                      TB300D
                      DIMENSION652
                      MM250X
                      MAXSTAR140
                      HT/PWR-MAX1250 PLASMA
