Diversion 180
  • Diversion 180
    Welders, ( I leave myself out of that category as I am only a hobbyist) I went and looked at the Diversion 180 today. Played with the thing and it seemed simply enough. The price is right and I want opinions on the TIG ability. I can see welding Stainless Steel and iron, but I am not sure I would ever weld aluminum. Would I be better off saving my money and buying a Dynasty, or is there a better machine?
    Do you have a stick machine ? The diversion is tig only. The syncro 200 will do tig and stick. Just thought I would mention.
      Diversion 180
      Thanks for the response. I will look at that one also.
      I got a great stick machine, Trailblazer 302. It's the second one I bought after the first one was stolen early last spring.
        Me too on the Trailerblazer 302. I would have bought a syncro 200 but got a super deal on a used 180 SD. I only use it for tig. My go to shop stick machine is a Miller CST 280.
          Diversion 180
          I also am a hobby welder. Just got a diversion 165, which is a bit less powerful, doesn't come with a foot pedal, and no MVP plug. I love the thing, wish I had the pedal and plug though. I would definitely recommend the diversion series. Small and convenient, but powerful enough for what I would weld.
          What are you welding over there?
            See Private Message.
              From one hobbyist to another... It was always my theory that if you buy a TIG welder you should include AC capability. If you have a TIG welder A) you will come across something aluminum which you need to weld or B) someone hearing that you have a TIG welder will say "can you weld this aluminum for me?"
              I purchased a Diversion 165 a little over 3 years ago. While I was trying to figure out the finger control torch (I had taken a TIG class 3 years before, was out of practice and had learned on a foot pedal) my step-son came by and said "can you weld aluminum?" He had two of sheets of aluminum which he wanted to use for some purpose but each had a couple of holes drilled in the middle. So the first thing I welded with the Diversion was someone else's aluminum
              That said, the Diversion was a great machine. However, I wanted pulse capability and sold it a couple of weeks ago and purchased a Dynasty 200 DX. It is a good thing we hobbyists don't have to cost justify our purchases
              Ken
                If you will not be tig welding aluminum, you just need a dc stick welder to tig weld steel/stainless steel.
                If you have a good dc stick machine, all you need is a tig torch with a gas valve, a bottle of argon and a regulator/flowmeter. This is scratch start and is very effective and economical way to tig weld ferrous metals. You will not have a foot peddle or auto gas control but for tig welding ferrous metals, you don't need that stuff.
                If your just a hobby welder, you will find you will rarely have the need to weld aluminum.
                Lincoln Idealarc 250
                Miller Bobcat 250
                Thermal Arc Hefty 2 feeder
                Thermal Dynamics Cutmaster 52
                Torchmate CNC table
                  I have a Diversion 180 and a Trailblazer 302. Since the 180 is so portable, I just plug it into the TB302 when I'm at a job site. I like the 180 but it would be nice to have pulse.
                  I agree with all those that say you will certainly have a need for AC one day.
                  Lincoln Vantage 400
                  Trailblazer® 302 Air Pak™
                  Miller Dynasty® 350
                  Millermatic 350P Aluminum
                  Millermatic® 252
                  Syncrowave 351
                  Lincoln LN-25 Pro
                  Multimatic™ 200
                  XR-Aluma Pro Gun
                  Diversion™ 180
                  Spectrum® 625 X-TREME™
                  Thermal Dynamics® Cutmaster® 52
                  Victor Oxy/Acetylene Set
                    I also agree, your friends will want you to weld aluminum. And it is so much fun.
