What's the best way to match the filler rod with base material? Does AWS put out any referencing information? I've got an idea of what to put on aluminum, but what about all the stainless parts out there? And what does that 'low fuming bronse' go on - die-cast materials? Not that I'll be welding ALL these base materials, but when that piece of titanium has to be repaired...I have to know what to butter it up with. Thanks, Andrew
Filler Rods
Andrew,
The American Welding Society (AWS) is a good source of information on filler metals, however AWS does not make specific recommendations for filler metal selection. The following specifications will give you information on physical and chemical make-up.
AWS A5.18 – filler metal for carbon steel
AWS A5.9 – filler metal for stainless steel
AWS A5.10 - filler metal for aluminum
AWS A5.16 – filler metal for titanium
I have some tables that I use for selecting filler metals that came from NASA. I only have tables for stainless steel and aluminum. I can email them to you if you think they may help. NASA probably would have some info on titanium welding.
I did a little research on your question concerning “low fuming bronze”, this material is typically used on copper, brass & bronze alloys. Did not find any reference for using it on cast material.
Hope this information is helpful. If you have any other questions, let me know.Kevin Disney
that might be helpful if you would email me those NASA tables. My email address is [email protected] Title it something obvious...I have a lot of spam. Thanks a bunch, Andrew
Originally posted by qq_ss_dd View PostDear Andrew,
Iam Lokking For The Tables Used In Filler Metal Selection Of Titanium Electrodes?
Would You Please Help Me
You say "titanium electrode", but I assume you mean filler rod.
these links are from jwharris..
Aluminum filler selection guide http://www.harrisproductsgroup.com/c...illerchart.asp
Stainless filler selection guide http://www.harrisproductsgroup.com/c...illerchart.asp
Experience also tells you when it's ok or beneficial to deviate from these charts a little. But they're a great starting point.
