The difference between cables
  • The difference between cables
    I can buy the standard Hardware cable which I thinks is 7 x 19 however I have a hanger door to repair so I think I might need to have some cable designed for overhead lifting.
    Also what is stronger, A cable clamp or a swagged aluminum sleeve, I was doing a little hunting and they recommend a copper sleeve over an aluminum sleeve for galvanized cable.
    I know how to install a cable clamp ( Never saddle a dead horse )
    I have the swagging tools because I do a fair amount of cable railings.
    Thanks.
    I like the sleeves as they look clean, but before there was sleeves there were clamps.
    I learned the dead horse thing when I worked for the Rail Road in Roseville.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    Trailblazer 302 Air Pak w/ Wireless Remote
    8-RC
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    Lincoln SA-200 Blue Tint Red Face '63
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
      A crimped sleeve is probably better, it doesn't slip or cut the cable. Sleeves are typical for that type of install. Better or best might not matter, sometimes adequate is the thing.
        I did a little research today and found out that a clamp reduces the cables rated capacity 20%. while with a sleeve it stays at 100%
